FINAL EDIT
Linux 6.19 is available already, so you only need to update your kernel.
- Debian: update to
trixie, enabletrixie-backportsand install updated Linux package:apt install -t trixie-backports linux-image-amd64- Alternatively use third-party kernel packages, such as Liquorix. - Ubuntu: Use third-party kernel packages, such as Liquorix, and wait for 26.04 release.
- Fedora: Update to latest Fedora version - 6.19 is available since Fedora 42.
- Arch Linux:
pacman -Syu
Leaving the previous contents of the post for reference.
EDIT: Final patch should be merged in 6.19 version, so in Spring 2026 these instructions won’t be needed anymore.
A lot of stuff happened since original workaround for getting sound working on Stoney Ridge chromebooks and stoney-kernel isn’t really maintained anymore.
Good news: we’re quite close to get the mainline kernel working as-is on Stoney
Bad news: You’ll need to compile the kernel manually, since we (chrultrabook team) don’t have enough time to provide prebuilt kernels.
Assuming you’re using latest and greatest Debian 13 (trixie), the instruction for compiling the patched kernel (in this case Liquorix) are as following:
# on any machine (building on stoney will take a lot of time):
sudo apt install docker git wget
git clone https://github.com/damentz/liquorix-package
cd liquorix-package
wget -O liquorix-stoney.patch https://forum.chrultrabook.com/uploads/short-url/levr5lUJL1DBamyUwErgcYEQpph.patch
git apply liquorix-stoney.patch
./scripts/debian/docker_bootstrap.sh
./scripts/debian/docker_build-source.sh debian trixie
./scripts/debian/docker_build-binary.sh amd64 debian trixie
# make a coffee, it will take some time
# on Stoney Ridge chromebook:
cd artifacts/debian/trixie
sudo dpkg -i *.deb
liquorix-stoney.patch (16.0 KB)
For other kernel packages (e.g. stock Debian kernel) and other distros, you’ll need to manually apply all of the following patches, depending on base version - consult your distro’s documentation for instructions on patching kernel.
- older than 6.15: https://github.com/torvalds/linux/commit/2b727b3f8a04fe52f55316ccb8792cfd9b2dd05d.patch
- older than 6.16: https://github.com/torvalds/linux/commit/51590571433e32cacce10b11051c6ff056bf0aa8.patch
- all versions: use this patch
