Build Stoney Kernel on Arch
Greetings. I saw this post about building kernel for stoney but it’s for debian. I’m very new to Linux and am using Arch linux (largely to learn this all vigorously).
A step-by-step guide would be most appreciated but general guidance (reference to verified guides, etc) would also help
The arch wiki has a general guide for compiling your own kernel. Make sure you modify the PKGBUILD to include the patch file linked in the post you referenced.
I am stuck here and have no idea what’s the matter(text extracted by ChatGPT after I uploaded the picture to it)
==> Validating source files with b2sums...
    linux-6.16.5.tar.xz ... Passed
    linux-6.16.5.tar.sign ... Skipped
    linux-v6.16.5-arch1.patch.zst ... Passed
    linux-v6.16.5-arch1.patch.zst.sig ... Skipped
    config ... Passed
==> Verifying source file signatures with gpg...
    linux-6.16.5.tar ... Passed
==> Extracting sources...
  -> Extracting linux-6.16.5.tar.xz with bsdtar
  -> Extracting linux-v6.16.5-arch1.patch.zst with zstd
==> Starting prepare()...
Applying /home/mutawir01/build/linux-liquorix-stoney/src/../patches-liquorix/liquorix-stoney.patch
patching file linux-liquorix/debian/patches/chrultrabook/01-asoc-amd-use-new-acp-dev-names-for-dai-links.patch
patching file linux-liquorix/debian/patches/chrultrabook/02-drm-amdgpu-use-static-ids-for-acp-platform-devs.patch
can't find file to patch at input line 288
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/linux-liquorix/debian/patches/series b/linux-liquorix/debian/patches/series
|index 9c2b2092..3e53148c 100644
|--- a/linux-liquorix/debian/patches/series
|+++ b/linux-liquorix/debian/patches/series
File to patch: _
Perhaps it is because I am using Debian’s patch? (the one I saw in the post mentioned earlier)
These are what I modified in the PKGBUILD
pkgbase=linux-liquorix-stoney
pkgdesc=‘Linux kernel with Liquorix and Stoney Ridge support’
prepare() {
  cd $_srcname
  # Apply Liquorix & Stoney patches
  for p in "${srcdir}"/../patches-liquorix/*.patch; do
    echo "Applying $p"
    patch -Np1 -i "$p"
  done
  echo "Setting version..."
  echo "-$pkgrel" > localversion.10-pkgrel
  echo "${pkgbase#linux}" > localversion.20-pkgname
#  local src
#  for src in "${source[@]}"; do
#    src="${src%%::*}"
#    src="${src##*/}"
#    src="${src%.zst}"
#    [[ $src = *.patch ]] || continue
#    echo "Applying patch $src..."
#    patch -Np1 < "../$src"
#  done
  echo "Setting config..."
  cp ../config .config
  make olddefconfig
  diff -u ../config .config || :
  make -s kernelrelease > version
  echo "Prepared $pkgbase version $(<version)"
I’m not too sure what I did wrong. These are the two patches I added in “./patches-liquorix”
https://forum.chrultrabook.com/uploads/short-url/levr5lUJL1DBamyUwErgcYEQpph.patch
(also, I am new to forum-style stuff so let me if I am not providing enough info or giving irrelevant info, and thanks WeirdTreeThing for the guidance initially)
Why are you trying to use Liquorix on Arch? Arch Wiki page linked by WTT already has all required commands to get sources for your kernel and how to add patches.
Ahh… So Liquorix is not a patch? Since it was part of the post itself, I thought it was also a patch (or, more specifically, the patch inside zen folder in the patches) hence why I added it in the patches
May you kindly provide me with all the required patches? I wish to avoid making this kind of stupid mistake again
I am also interested in which patch should be applied to a stock kernel for archlinux.
For other kernel packages (e.g. stock Debian kernel) and other distros, you’ll need to manually apply all of the following patches
and there are two patches, one is for kernel <6.15 and the second for >6.16. I downloaded stock 6.17.7 from kernel.org and tried to apply the patch for kernel >6.16, but it appeared that the patch was already applied.
Question: Do I need to apply the patch for <6.15 too? @WeirdTreeThing ?
For the latest kernel, all you need is the amdgpu patch. You can even get it directly from the lkml Making sure you're not a bot!
Aha, thanks for the tip. Gonna try.
For those interested:
Take commit 43de1b163dc572dc4061c9baf005216e3ce11348 from archlinux kernel package , put amd-gpu.patch in the root dir and add amd-gpu.patch to the sources in PKGBUILD. Or simply use PKGBUILD below:
# Maintainer: Jan Alexander Steffens (heftig) <[email protected]>
pkgbase=linux
pkgver=6.17.7.arch1
pkgrel=1
pkgdesc='Linux'
url='https://github.com/archlinux/linux'
arch=(x86_64)
license=(GPL-2.0-only)
makedepends=(
  bc
  cpio
  gettext
  libelf
  pahole
  perl
  python
  rust
  rust-bindgen
  rust-src
  tar
  xz
  # htmldocs
  graphviz
  imagemagick
  python-sphinx
  python-yaml
  texlive-latexextra
options=(
  !debug
  !strip
_srcname=linux-${pkgver%.*}
_srctag=v${pkgver%.*}-${pkgver##*.}
source=(
  https://cdn.kernel.org/pub/linux/kernel/v${pkgver%%.*}.x/${_srcname}.tar.{xz,sign}
  $url/releases/download/$_srctag/linux-$_srctag.patch.zst{,.sig}
  amd-gpu.patch
  config  # the main kernel config file
validpgpkeys=(
  ABAF11C65A2970B130ABE3C479BE3E4300411886  # Linus Torvalds
  647F28654894E3BD457199BE38DBBDC86092693E  # Greg Kroah-Hartman
  83BC8889351B5DEBBB68416EB8AC08600F108CDF  # Jan Alexander Steffens (heftig)
# https://www.kernel.org/pub/linux/kernel/v6.x/sha256sums.asc
sha256sums=('ddf2ea0d4439e1d57136be3623102af9458f601f5b1cb77e83246e88aea09d0e'
            'SKIP'
            '8bb8d08a419971c0cf96346de3de69c980e0c9a384f46cca49ca9c74eb60343a'
            'SKIP'
            'SKIP'
            '4e6c3f6a35fed3e2bee7309d430ddf87b435ffb6e697c5d53a6c2eb73c42079a')
b2sums=('7338c33e209a87d2acdc80cb30066b719a1924ac38db0ac4087c4cb2ae6d510d75fbc97eeadac9bbc070afe09f29e65fd7ab18383fe677adcf993c17d4407535'
        'SKIP'
        '446bbb888e4588285d9629b6142420a308919105612d81cc9add844857c6930caf8fa8477e3120f51a596609f4aba6f166447902fc6936ba8c60870976690db2'
        'SKIP'
        'SKIP'
        '7d8b33b9ef36bbd599ad283210d19c8f6a481ac3e540be0ac519c4942865bf8a25f01bfcfba4ff4c6fc237a5d7586eb6bb0fbf3eb657d5df6856bd4395475f78')
export KBUILD_BUILD_HOST=archlinux
export KBUILD_BUILD_USER=$pkgbase
export KBUILD_BUILD_TIMESTAMP="$(date -Ru${SOURCE_DATE_EPOCH:+d @$SOURCE_DATE_EPOCH})"
prepare() {
  cd $_srcname
  local src
    src="${src%%::*}"
    src="${src##*/}"
    src="${src%.zst}"
  done
  make olddefconfig
build() {
  cd $_srcname
  make all
  make -C tools/bpf/bpftool vmlinux.h feature-clang-bpf-co-re=1
  make htmldocs SPHINXOPTS=-QT
_package() {
  pkgdesc="The $pkgdesc kernel and modules"
  depends=(
    coreutils
    initramfs
    kmod
  optdepends=(
    'linux-firmware: firmware images needed for some devices'
    'scx-scheds: to use sched-ext schedulers'
    'wireless-regdb: to set the correct wireless channels of your country'
  provides=(
    KSMBD-MODULE
    NTSYNC-MODULE
    VIRTUALBOX-GUEST-MODULES
    WIREGUARD-MODULE
  replaces=(
    virtualbox-guest-modules-arch
    wireguard-arch
  cd $_srcname
  local modulesdir="$pkgdir/usr/lib/modules/$(<version)"
  echo "Installing boot image..."
  # systemd expects to find the kernel here to allow hibernation
  # https://github.com/systemd/systemd/commit/edda44605f06a41fb86b7ab8128dcf99161d2344
  install -Dm644 "$(make -s image_name)" "$modulesdir/vmlinuz"
  # Used by mkinitcpio to name the kernel
  echo "$pkgbase" | install -Dm644 /dev/stdin "$modulesdir/pkgbase"
  echo "Installing modules..."
  ZSTD_CLEVEL=19 make INSTALL_MOD_PATH="$pkgdir/usr" INSTALL_MOD_STRIP=1 \
    DEPMOD=/doesnt/exist modules_install  # Suppress depmod
  # remove build link
  rm "$modulesdir"/build
_package-headers() {
  pkgdesc="Headers and scripts for building modules for the $pkgdesc kernel"
  depends=(pahole)
  cd $_srcname
  local builddir="$pkgdir/usr/lib/modules/$(<version)/build"
  echo "Installing build files..."
  install -Dt "$builddir" -m644 .config Makefile Module.symvers System.map \
    localversion.* version vmlinux tools/bpf/bpftool/vmlinux.h
  install -Dt "$builddir/kernel" -m644 kernel/Makefile
  install -Dt "$builddir/arch/x86" -m644 arch/x86/Makefile
  cp -t "$builddir" -a scripts
  ln -srt "$builddir" "$builddir/scripts/gdb/vmlinux-gdb.py"
  # required when STACK_VALIDATION is enabled
  install -Dt "$builddir/tools/objtool" tools/objtool/objtool
  # required when DEBUG_INFO_BTF_MODULES is enabled
  install -Dt "$builddir/tools/bpf/resolve_btfids" tools/bpf/resolve_btfids/resolve_btfids
  echo "Installing headers..."
  cp -t "$builddir" -a include
  cp -t "$builddir/arch/x86" -a arch/x86/include
  install -Dt "$builddir/arch/x86/kernel" -m644 arch/x86/kernel/asm-offsets.s
  install -Dt "$builddir/drivers/md" -m644 drivers/md/*.h
  install -Dt "$builddir/net/mac80211" -m644 net/mac80211/*.h
  # https://bugs.archlinux.org/task/13146
  install -Dt "$builddir/drivers/media/i2c" -m644 drivers/media/i2c/msp3400-driver.h
  # https://bugs.archlinux.org/task/20402
  install -Dt "$builddir/drivers/media/usb/dvb-usb" -m644 drivers/media/usb/dvb-usb/*.h
  install -Dt "$builddir/drivers/media/dvb-frontends" -m644 drivers/media/dvb-frontends/*.h
  install -Dt "$builddir/drivers/media/tuners" -m644 drivers/media/tuners/*.h
  # https://bugs.archlinux.org/task/71392
  install -Dt "$builddir/drivers/iio/common/hid-sensors" -m644 drivers/iio/common/hid-sensors/*.h
  echo "Installing KConfig files..."
  find . -name 'Kconfig*' -exec install -Dm644 {} "$builddir/{}" \;
  echo "Installing Rust files..."
  install -Dt "$builddir/rust" -m644 rust/*.rmeta
  install -Dt "$builddir/rust" rust/*.so
  echo "Installing unstripped VDSO..."
  make INSTALL_MOD_PATH="$pkgdir/usr" vdso_install \
    link=  # Suppress build-id symlinks
  echo "Removing unneeded architectures..."
  local arch
  for arch in "$builddir"/arch/*/; do
    [[ $arch = */x86/ ]] && continue
    echo "Removing $(basename "$arch")"
    rm -r "$arch"
  done
  echo "Removing documentation..."
  rm -r "$builddir/Documentation"
  echo "Removing broken symlinks..."
  find -L "$builddir" -type l -printf 'Removing %P\n' -delete
  echo "Removing loose objects..."
  find "$builddir" -type f -name '*.o' -printf 'Removing %P\n' -delete
  echo "Stripping build tools..."
  local file
  while read -rd '' file; do
    case "$(file -Sib "$file")" in
      application/x-sharedlib\;*)      # Libraries (.so)
        strip -v $STRIP_SHARED "$file" ;;
      application/x-archive\;*)        # Libraries (.a)
        strip -v $STRIP_STATIC "$file" ;;
      application/x-executable\;*)     # Binaries
        strip -v $STRIP_BINARIES "$file" ;;
      application/x-pie-executable\;*) # Relocatable binaries
    esac
  done < <(find "$builddir" -type f -perm -u+x ! -name vmlinux -print0)
  echo "Stripping vmlinux..."
  strip -v $STRIP_STATIC "$builddir/vmlinux"
  echo "Adding symlink..."
  mkdir -p "$pkgdir/usr/src"
  ln -sr "$builddir" "$pkgdir/usr/src/$pkgbase"
_package-docs() {
  pkgdesc="Documentation for the $pkgdesc kernel"
  cd $_srcname
  echo "Installing documentation..."
  local src dst
  while read -rd '' src; do
    dst="${src#Documentation/}"
    dst="$builddir/Documentation/${dst#output/}"
    install -Dm644 "$src" "$dst"
  done < <(find Documentation -name '.*' -prune -o ! -type d -print0)
  mkdir -p "$pkgdir/usr/share/doc"
  ln -sr "$builddir/Documentation" "$pkgdir/usr/share/doc/$pkgbase"
pkgname=(
  "$pkgbase"
  "$pkgbase-headers"
  "$pkgbase-docs"
for _p in "${pkgname[@]}"; do
  eval "package_$_p() {
    $(declare -f "_package${_p#$pkgbase}")
done
# vim:set ts=8 sts=2 sw=2 et:
amd-gpu.patch is below:
diff -ruN linux-6.17.7/drivers/gpu/drm/amd/amdgpu/amdgpu_acp.c linux-6.17.7-new/drivers/gpu/drm/amd/amdgpu/amdgpu_acp.c
--- linux-6.17.7/drivers/gpu/drm/amd/amdgpu/amdgpu_acp.c	2025-11-02 14:18:05.000000000 +0100
+++ linux-6.17.7-new/drivers/gpu/drm/amd/amdgpu/amdgpu_acp.c	2025-11-02 23:55:00.302775863 +0100
@@ -302,17 +302,19 @@
 		adev->acp.acp_res[2].end = adev->acp.acp_res[2].start;
 		adev->acp.acp_cell[0].name = "acp_audio_dma";
+		adev->acp.acp_cell[0].id = 0;
 		adev->acp.acp_cell[0].num_resources = 3;
 		adev->acp.acp_cell[0].resources = &adev->acp.acp_res[0];
 		adev->acp.acp_cell[0].platform_data = &adev->asic_type;
 		adev->acp.acp_cell[0].pdata_size = sizeof(adev->asic_type);
 		adev->acp.acp_cell[1].name = "designware-i2s";
+		adev->acp.acp_cell[1].id = 1;
 		adev->acp.acp_cell[1].num_resources = 1;
 		adev->acp.acp_cell[1].resources = &adev->acp.acp_res[1];
 		adev->acp.acp_cell[1].platform_data = &i2s_pdata[0];
 		adev->acp.acp_cell[1].pdata_size = sizeof(struct i2s_platform_data);
-		r = mfd_add_hotplug_devices(adev->acp.parent, adev->acp.acp_cell, 2);
+		r = mfd_add_devices(adev->acp.parent, 0, adev->acp.acp_cell, 2, NULL, 0, NULL);
 		if (r)
 			goto failure;
 		r = device_for_each_child(adev->acp.parent, &adev->acp.acp_genpd->gpd,
@@ -410,30 +412,34 @@
 		adev->acp.acp_res[4].end = adev->acp.acp_res[4].start;
 		adev->acp.acp_cell[0].num_resources = 5;
 		adev->acp.acp_cell[2].name = "designware-i2s";
+		adev->acp.acp_cell[2].id = 2;
 		adev->acp.acp_cell[2].num_resources = 1;
 		adev->acp.acp_cell[2].resources = &adev->acp.acp_res[2];
 		adev->acp.acp_cell[2].platform_data = &i2s_pdata[1];
 		adev->acp.acp_cell[2].pdata_size = sizeof(struct i2s_platform_data);
 		adev->acp.acp_cell[3].name = "designware-i2s";
+		adev->acp.acp_cell[3].id = 3;
 		adev->acp.acp_cell[3].num_resources = 1;
 		adev->acp.acp_cell[3].resources = &adev->acp.acp_res[3];
 		adev->acp.acp_cell[3].platform_data = &i2s_pdata[2];
 		adev->acp.acp_cell[3].pdata_size = sizeof(struct i2s_platform_data);
-		r = mfd_add_hotplug_devices(adev->acp.parent, adev->acp.acp_cell, ACP_DEVS);
+		r = mfd_add_devices(adev->acp.parent, 0, adev->acp.acp_cell, ACP_DEVS, NULL, 0, NULL);
 		if (r)
 			goto failure;
Then compile and install obtained package.
