Headless chromebook(lillipup) - no display output for firmware screen
  • Device: LILLIPUP
  • OS: Arch linux
  • Firmware Version: 2026.07.09 / 2606.6
  • Internal storage type: NVMe
I converted my chromebook to a headless one, the original screen removed.
When I boot there is NO SIGNAL on my display until display outputs as normal when in sddm an desktop environment.
I cannot access firmware on the external monitor at all.
What is not displayed: edk2, grub menu entries, decryption field and verbose post-decryption info.
Hardware is OK - tested with different pc and monitor.
  1. Disconnect the LCD unit completely
  2. Boot up
External display shows output on the firmware screen and grub.
Linked topics
Boot into uefi from the OS
still no output.
@MrChromebox(sorry for the ping) I’m guessing this involves the firmware, if so, is it possible to fix this?
ping me on discord and I’ll give you a test build to try
Where can I find your discord, is this a group I need to join?
also I don’t mind flashing the test build but can the test build possibly brick my device?
because I cannot unbrick my chromebook since I got no hardware for unbricking.
no, this would just be testing things to try and get the external display functional
I also updated to the latest 2606.6 release just so you know in case this may affect testing.
ok then, I’m good to go then, how do I contact you on discord?
how does one contact anyone else on Discord?
right… I sent you my username in a DM.DM me on discord if it is fine with you.
Testing complete, MrChromebox will update upstream if no further issues are found :slight_smile:
Fixed in 2606.1 release
