ok so the firmware kinda works im not bios bricked or anything like that but when it booted it said there was no os or that it was broken so i tried installing the recovery and it installs and then i get the same message when booting and i dont have rw_legacy firmware installed after that so i dont know what to do please help
ok so my problem is exactly like his :TPM initialization error on acer chromebook CB 314 N19Q2, but resetting the tpm does nothing please help
If your using RW_LEGACY, then that is a boot loader problem. Same thing happens on my Chromebook. Did you have to manually install the boot loader?
No it installed from the script
I meant i don’t have RW legacy so I don’t know what to do
Not RW_LEGACY. I meant a bootloader like GNU GRUB.
Same thing for Full Rom
idk i just had the chrome os bootloader after running the script and i have the tpm 0x2b error nvram communication error and my fmver is 00000000 and kernver is 00010004
I am not sure then. Maybe try re-running the script?
cant run the terminal because i cant boot into chrome os and the shell in the bootloader doesnt work
i meant i am stuck in the chrome os bootloader after running the script
Try making a ChromeOS Boot Drive. There’s an extension on the Chrome Web Store for that.
Bro it doesn’t work
