im struggleing on how to get my audio on my stoney working its codenamed barla and runs it fine but im not sure how to get the audio to work
I too can not get this to work on my barla chromebook, Like it worked on windows, and then i switched to debian and ran the weirdtreething audio kernel, but no sound came out of the speakers when i tried to rickroll someone
May I suggest taking a look at this page of the chrultrabook docs? It links to the audio script.
Needs kernel compiled with AMDGPU=Y instead of =M and firmware built-in to get working audio
You need a non default kernel. Stoney Kernel arch linux
I installed this one and rebooted then interrupted the startup to switch to the stoney kernel and the audio started working. You need it AND the audio script.
