Can anyone give me a guide to install the StoneyRidge custom kernel on arch linux?
Thanks
gvalue
Thanks
gvalue
stoney/vmlinuz-6.6.16-stoney to /bootstoney/modules/lib/modules/6.6.16-stoney to /usr/lib/moduleskernel-install add 6.6.16-stoney /boot/vmlinuz-6.6.16-stoneyCould I please have some help? I have tried using this guide, but I am having issues with moving the files. I have tried dragging the vmlinuz to boot, but it doesn’t let me. Then I tried using the mv command, and it removed it from the stoney file, but I could not see it in the boot file.
sudo mv stoney/vmlinuz-6.6.16-stoney /boot
In terminal, you will need sudo to have permissions to access that directory
my dad told me that downloading prebuilt kernels is super unsafe, can anyone let me know if this is a good one? i know it was recommended by weirdtreething in their audio setup script, but still
Do we know if the stoney kernel will be updated with any regularity?
I think i found one latest version of the kernel
here:Enable binderfs · chrultrabook/stoney-kernel@2896132 · GitHub
Please check artifacts.You need account to access that file.
Sorry, I don’t follow. I have a GitHub account and logged in to look at that post. All I see is that it shows the stoney-kernel artifact is expired.
I am wondering if the original compiler or maintainer of the kernel is on this forum anywhere and if s/he will update it past 6.6.
I finally got the kernel to install i had to update grub first but when i boot into it it doesnt load it just black screen how do i fix this?
For Ubuntu “Plucky,” you have to install the deb files from here: Index of /stoneyridge-kernel/ubuntu-6.14.0-15.15_all/ Then, delete the vmlinuz file for the previous kernel from the /boot folder and run “sudo update-grub.”
is it just this? or first this steps then the steps above? would really appreciate if you can give me a step by step guide for plucky.
Forgot to mention, I also think you have to delete the “config” file and the “system.map” file that match your previous kernel. Other than that and any files in the main /boot folder that match the kernel number, that’s basically it.
Sorry, made a mistake. Instead of installing the deb files from the link provided, get the one here and install it: https://github.com/GamePlayer-8/stoney-kernel/releases/download/v1.0.1/kernel-debian.deb
