is your device the clamshell or convertible version? I cannot reproduce this here at all on my Drallion.
hello mrchromebox , brother I m facing this issue since I have installed windows on my Chromebook 7410 x360 , if u have solve the issue kindly guide me to remove the self shutdown issue from my 7410 chromebook , I’m facing this problem in windows only , as I have installed Linux, ubantu and fydeos ,all are working fine except windows 10 and 11
second question : The backlit keyboard of my chromebook 7410 not working in Linux ,ubantu and fydeos , do u have the solution , the backlit kb works In windows but not in other operating systems .
one more question plz :
I have tried so many times to disable write protection from my 7410 chromebook but failed , kindly tell me how to disable the Fw WP as I have disconnected the battery but still the wp was not disabled…
Fw type ; full rom /uefi
Fw ver: MrChromebox-2405.0-4-g2caa715d941 (6/23/24)
Fw Wp; enabled
not sure what I can do, I’m not a Windows dev, no idea why Windows would be behaving differently than Linux in this regard
Linux kernel driver bug
if it’s already flashed with the UEFI firmware, then WP should be disabled otherwise, how could you have flashed the device.
This is what the script is reporting? What OS are you running it from?
thanks for the fast reply , my friend flashed the uefi firmware by removing the ic from the board and flashed through programmer… now I cannot convert it back to chromeos as it shows write protection
ok leave it bro
kindly tell me how to install the backlit driver in Linux ?? I left Linux because of this small issue that the backlit kb doesn’t work …
regards
the drivers are broken, not something I can fix
My notebook can flip 360 degrees
There is another problem. When I flip to 360 degrees, I can’t enter tablet mode whether in fydeos, windows, or Ubuntu.
ok brother , thank u
