Hi, yesterday flashed my dell chrome 7410 (Drallion) with latest available rom from @mrchromebox with coolstar script, installed windows 10 x64, all devices works fine, but there is a bug, shutdown is self activated at 30% battery remain, if i turn on my chrome again continue working for about two hours more.
Thanks for you fast reply. Do you know which was latest version working without that issue? Or were worst issues in old versions? A user comments that he flashed about 20 chrome devices a time ago and all were working fine.
Excellent, in mean time im testing with critical battery level to “make nothing” when the “Critical Battery Trigger Met” event occurs with next cmd command:
Hi,
I also face the same issue. I downgraded the firmware to 4.19, but the issue was still there.
I just give up for now. @MrChromebox , I noticed that 2 battery are declared in ec/google/wilco/acpi/battery.asl
Is it possible to remove the ghost battery ? or one wilco device have two batteries?
I’m not aware of any shipped Wilco device with 2 batteries, or any upcoming ones either (thankfully), so I suppose it wouldn’t hurt to remove the support for the 2nd battery
