Won't boot without internal display connected on Samsung Chromebook 2 11 - XE500C12 Chromebook Winky
Just updated to the latest MrChromebox firmware and and realized through trial that the device won’t boot without the internal display connected. Prior to this I was on firmware version 4.20.1 and could boot with just the HDMI connected to a monitor (not sure about headless booting). This would also show the Bios screen.
Now it just powers up (shown by the led indicator) if the internal display isn’t connect, but there is no indication of anything else happening. Pressing the power button once even after 5 minutes turns off the led. HDMI shows no indication of receiving a signal through all this period.
If I power down and attach the internal display, everything works. HDMI output operates like it did with the screen attached before, only after the bios screen. Is there any remedy to this? For my application, I need to remove the internal display.
bro if I may ask how did you enter your winky into recovery mode because Ihave been trying and I cannot get it no matter what
