I’m currently running Ubuntu on my Asus Chromebook Cx1500CKA I installed it using the mrchromebox.tech firmware utility script. Yesterday I tried to install windows 11 on my chromebook just to see how it works and got an “error” saying: “A media driver your computer needs is missing” etc. And I thought nothing of it I looked on the internet for some solutions but didn’t found any drivers, but then I found coolstar.org. I tried to install the drivers and they were obviously compatible with My chromebook, but i got another error saying: “No new devices drivers were found” etc. Does anyone have the same problem or knows how to bypass that or does anyone have the drivers?
[Uploading: 1000006023.jpgProcessing: 1000006012.jpg…Processing: 1000006011.jpg…
“media driver is missing” = you created the install media incorrectly, or are using a modified ISO which is missing the required drivers. There is nothing you can install/provide to fix this.
Tysm it worked
I’m having the same issue
I have tried an SD and USB drive, multiple ISO’s, multiple USB burners, direct from Microsoft and from 3rd parties. I’ve tried multiple laptops of the same model, still no dice. I really don’t think I’m doing anything wrong here. Any guidance would be appreciated.
