there seems to be an audio issue after getting windows 10 installed on this Chromebox 3 cn65 teemo, i found while searching with the hdw id, a driver that seems to have fixed this issue with minimal effort. its a driver for Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller, found here
https://driverpack.io/en/hwids/PCI\VEN_8086%26DEV_9D71%26CC_0401?os=windows-10-x64
i dont always trust these sites so use at your owk risk, go find the missing drivers under device manager and point the search to the unzipped folder.
if you can find a better more direct download from intel for this i would go there but this was a solution to this problem.
