Hi,
I have an Acer Chromebook 15” CB315-3HT-P297. According to Supported Devices | MrChromebox.tech I can see that HWID/Board Name is “BLORB” - I checked it myself and it is correct.
But now the WP method says: CR50 (SuzyQ, battery) - does this mean that I need ONLY a cable or that I can do this ONLY with the battery? Or do I have to do/use BOTH?
The light on the charging socket only flashes orange, but the laptop won’t turn on. As soon as I plug the battery back in, the PC boots and can also be charged normally with the charger.
If I need a SuzyQ cable, where can I buy one? It needs also to be shipped to Germany.
I just want to wipe ChromeOS and the Bootloader, flash the full UEFI ROM and install Linux Mint.
You need the cable OR disconnect battery. However, if your CB won’t boot without battery then you will need the cable. I would try with a different ac adapter before buying a cable though, if you have a 65w adapter, try that.
Hi were you able to remove WP? I have a Asus Chromebook C563 i3 11th gen and it simply wont boot without the battery, so did you try the SuzyQable or did the 65Watt charger work?
If I get SuzyQable, its a guaruntee work but if I get the charger and doesn’t work then I have it for no reason
