Is it impossible to get my hands on a SuzyQuable now? I’ve been searching for a while, but every source seems to be sold out. I’ve been stuck on the legacy firmware with limited storage and really want to switch.
You need to make one yourself, search yt for a tutorial
not recommended, but you could possible open up your device, disconnect the battery, then flash full firmware, and then reconnect the battery or something along those lines
That is the most recommended one and easier than the suzyQable hussle
oh i was wrong ig
all i know is that its the easiest one
disconnecting the battery works for some, but definitely not all devices. There’s a reason we have a list with the WP disablement method for every single device
Most common HW methods are WP screw, battery, and sometimes jumpering
There’s a seller on ebay who sells an adapter you use with a usb-c cable, I used it with my C13 Yoga Gen 1 and it worked
Chromebook Debug Board / “SuzyQ” / “SuzyQable” adapter for Cr50 / Ti50 | eBay
