What's the best linux distro for a Dedede?
Hello, I have a Acer R753T with 4 gb of ram, 32 gb of storage and a Intel Celeron N5100.
I’m looking for a Linux distro that supports everything (touchscreen, USB, SD card, sound, WIFI, trackpad…) What would be the better option? Thanks in advance.
alpine is lightweight, although it aint the nicest install experience imo
You can also try Fedora or Arch. The desktop environment probably matters more. If GNOME and KDE Plasma are too heavy for your Chromebook, you should try XFCE.
I think with those specs you should be fine if you avoid Snaps, Flatpak, and NixOS since those 3 use up slightly more space.
