What OS is reccomended on a HP Chromebook 11 G5 (Not the EE model)
I’m looking for an OS for my old Chromebook, and I don’t know what OS I need for it. I looked at the requirements for Windows 10, and that won’t work, so I need something for linux. If you need the specs then here they are:
Intel Celeron N3060 (64-bit mobile CPU)
4 GB of DDR3L Memory
16 GB of eMMC storage
And if it helps,
Intel HD graphics 400.
Have you tried SparkyLinux? SparkyLinux is a lightweight Debian based distro with some easy to use features as well as a few choices in desktop enviroment, it also has a semi-rolling release version too if you want that. I’ve used it a couple times on my desktop. Another would be Q4OS, also Peppermint Linux is a good option. Also of you can, get an SD card in there with a lot of space, while I doubt SparkyLinux or any of the other distros would take up much space, it would still be a good idea.
