when I try to install on arch it shows 4 hard drives and I don’t know what hard drive to use. how do I figure out what hard drive to use?
how are we supposed to know what you’re looking at with zero info provided?
he is trying to tell you to help him get his nvme0p checked
I wouldn’t bet on it
here is some details.
i have a dell chromebook 3110 2 and 1
running RW-legacy
storage 64 GB
how about a picture of what the installer is offering?
are you trying to dual boot?
have you set up the Linux partition already using CRAP?
also what is CRAP?
sure, cut off the useful part to the right side
well crap it cropped the path
is there a reason you’re using RW_LEGACY and not full ROM?
i cant disable WP. i took out the screw but its still write protected
yeah, because that one isn’t a screw. your WP method is in the docs.
tried that too. failed
i mean. i can try again?
let me see if i can do it
nice i found out that dell has instructions on how to disable WP
https://www.dell.com/support/kbdoc/en-us/000209812/chromebook-3110-and-3110-2-in-1-rma-shim-process
