This is on stock ROM on multiple boards in the past few weeks. Not sure if it’s due to an update or just a coincidence but thought this would be the best place to ask.
Getting the following error when trying to modify VPD on ChromeOS. WP is disabled.
Warning vpd: [flashrom.cc(46)] At least some flash regions are read protected. You have to use a flash layout and include only accessible regions. For write operations,
You’ll additionally need the –noverify-all switch. See manpage for more details”
I know with flashrom, you can specify the region with --ifd -i bios, but not sure if this is possible with VPD. I imagine reading with flashrom, modifying the file with VPD, then writing is an option but if anyone knows why this is happening and if there is a way to fix with only using VPD that would be much appreciated!
well, the error is pretty explicit - the file size doesn’t match the region to which you are trying to write it. The RO_VPD region / vpd.bin file should be 16kb (16384 bytes). Is the fille 16k after reading via flashrom?
But again, why are you reading via flashrom when you can simply run vpd -s "serial_number"="newserial" and not have to deal with explicit reads/writes?
Also, that screen/device is crying out for a good dusting/wipe down =D
I noticed today that this vpd warning appears after a recent update to ChromeOS. Everything still works, but the warning displays each time.
@MrChromebox do you know why it warns “cannot read inside Device Expansion Region” and what Device Expansion region is? Like I said z everything still works but I just want to understand what’s happening if possible.
Ok I’ve noticed it mostly on fleex so that makes sense. Even though it works I’ve had many people tell me the command stopped working so that’s been fun haha
