Volume Hotkeys on Linux from chromebook
Hello, Finally got Linux Fedora 42 or 41 i dont remeber XCFE running on my HP Chromebook 11 G6 EE. The sound started working after I sudo dnf get updates and i have limited the max audio voulme to 80 on pulseaudio control panel it works perfectly but is there any way to get the audio increase mut and dcrease buttons to do its functions as in chrome os in linux as well? not limited to the audio controls but also the brightness controls? currently I’m pretty sure its being used as function keys
would appreciate any help also thank you all devs who made this possible
if only there was some documentation with post-install setup for things like this…
relax cuh i didnt know matey matey
