Ventoy command not working
When trying to run the command
mv /home/chronos/user/Downloads/ventoy--linux.tar.gz
in the developer console, it tells me “mv: missing file operand after ‘home/chronos/user/Downloads/ventoy--linux.tar.gz’”, even though ventoy is installed and I did all prior steps. I’m using ventoy 1.1.05 if that helps.
Add another directory. This is as if you were asking to move something but don’t tell the person where it should be moved.
Im just going to remove this. It causes more confusion than it helps.
