I’m having bother charging my laptop from a 100W / 5V USB-PD system, which is odd because it worked fine when it was a Chromebook. The Linux system seems to recognise it as a power source, but doesn’t enable charging. See attached pics. It does charge it when it’s shut down, just not when powered on. Is there a setting I need to change / some script I can run to correct things ? I’m trying to run some boat applications and USB-PD is all that’s available power wise.
Does the charging light on your laptop turn on? If so, it’s charging but isn’t being recognized by Fedora. Otherwise, they may be an underlying issue…
