- Device: [SWANKY]
- OS: [ChromeOS]
- Firmware Type: [stock-firmware-SWANKY-20261029.rom]
- Firmware Version: [stock-firmware-SWANKY-20261029.rom]
- Internal storage type: [] (if applicable)
During the update process when trying tyo run the util script the network is unavailable
Esc Refresh Power
Ctrl D Enter
Login as chronos in terminal shell
[Need to run the script from mrchromebox web site, ie https://mrchromebox.tech/firmware-util.sh but inspite of using various IP commands to try to start eth0 or wlan0 network is not available. I am using UGREEN USB to RJ45 for eth0. Also the at this stage the file system says read only so cannot update the resolve.conf file. Can I use a Live Lubuntu stick to fix the network? If so how. I have removed the sticker to remove write-protection]
