I am very new to ChromeOS and its alternatives so apologies if my question is very obvious. I just wanted to check in with the experts before I give up on this.
I have an Asus Chromebook Flip C434 and it doesn’t boot. It says “ChromeOS is missing or damaged”. I tried the Recovery Utility but it also failed after checking the USB with “an unexpected error”.
As far as I can tell, dev mode isn’t enabled on this Chromebook, since I can’t seem to open up any kind of terminal with CTRL + F2/F3 or with CTRL+T on the “OS verification is off” screen. It also doesn’t allow me to boot from USB.
Since I don’t know what I’m doing, I also tried removing the battery connection on the motherboard and try booting via the adapter directly. That way it entered an endless boot loop of the “OS verification is off” screen. Not sure what this indicates.
When I press CTRL + F2 during an error screen, I get some log screen and it says “SSD for installation not specified”.
Here are some more details in case it says something to you:
I have also seen a topic here and the OP seemed to have managed to revive the Chromebook and use an SD card to boot something else. This is what I would like to do as a last resort but I don’t have any of the mentioned tools for the process, nor I am technical enough to probably do this successfully.
the image posted shows the device in recovery mode because you booted it there via the recovery keys – that tells us nothing. power off, then power on normally, and let it fail and go to recovery, then press tab and take a picture of the upper left – that will tell you the reason it failed to boot.
I couldn’t find the SuzyQ where I am unfortunately.
I opened up the CB and found a “Winbond 25q128jvsq” on it. I believe this is the chip I need to flash something via ch341a? I went ahead and ordered a kit.
I have no clue how to do this yet but once it arrives, I’ll be going over the documentation and watch some beginner videos. Wish me luck!
As a side note, I also contacted ASUS in the meantime and they asked about €200 to repair this, basically 1/3 of what I paid when it was new…
I thought the chip clip would just hold onto this and I would be able to flash. Wouldn’t that work because the chip isn’t “high” enough while it’s on the board? Or is it because it’s a different size?
The link you shared doesn’t seem to ship where I am. Would you let me know the exact part name I need? Apologies for many questions, these things look extremely complicated for my level.
As you can see in the picture, the soic-8 chip has legs and that is the type of chip you can just clip on to.
Your CB uses the wson 6x5 chip which does not have legs so there’s nothing to clip on to.
The clip you need is a pogo pin adapter. Refer to the link I shared above for what it should look like or other names it may go by. You need one for a wson 6x5.
