Unable to enter Recovery mode in Asus Chromebook Plus
  • Device: [ChromeOS board name]
  • OS: [ChromeOS, Linux, Windows]
  • Firmware Type: [Stock, RW_LEGACY, UEFI Full ROM]
I have a Chromebook Plus Model CX3402CB-PQ0513
The os details are:-
Version 148.0.7778.250 64 bit
Platform 16640.570 stable channel byra
F/w Marasov.14505.884.0
ARC enabled - true
ARC 15461314
enterprise enrolled false
dev mode false
It runs on an Intel i5-1235u cpu and has 8gb ram
My problem is I would like to remove the Chromebook os and replace it with a Linux os but I can’t access Recovery mode.
  1. I have tried holding down esc and refresh and then pressing power for a short time.
  2. I have tried holding down esc and refresh and power for >10 sec. No difference.
  3. I have tried holding down esc and maximise and pressing power for a short time.
  4. I have tried a Hard reset and a Factory reset.
I was expecting the device to enter Recovery Mode but it just runs up normally.
Can someone help me out?
Hard reset works, which means refresh + power work. Are you sure the ESC key works?
