I transform my akali360 into ultrabook successfully but the ec drivers on this model seems to be a little broken. Its not a game changer, but in normal laptop mode, i canot use autorotate function, so also im unable to use in tent mode. As far with this, in tablet mode thouchpad is still active so i can move cursor when im using touchcreen and device is fold like tablet. It seems that it is a problem with bloking some data from sensor to disable some active devices.
Second problem is worse… After pluging laptop to charging universal power delivery charger with 65w of power, cpu instantly goes to throttling. Useful program called throttle stop tels me that it is caused by BD_PROHOT limiter and cpu is jumping from 700mhz to 1.1ghz. Deveice is unusable then… After unpluging ftom charging everything working fine, cpu is boosting to 3,4ghz and runs fine. The problem occurs on three diffrent chargers and cables, but interestingly not on orginal charger that comes with my chromebook, and also on another type c for lenovo thinkpad.
Also it will be good to have working dedicated volume buttons on this model.
