Touchscreen (and more) not working, Morphius FW 01/13/2026
Updated UEFI full firmware to latest version using the firmware-util script. The touchscreen no longer works.
In windows it shows a warning icon next to ‘i2c hid device’. In linux (6.18.4), the touchpad, trackpoint, trackpoint buttons additionally don’t work.
I’ll provide more info if requested. I’m not sure what exactly to provide. (I mistakenly posted this in the support section earlier if it looks familiar)
the docs tell you how to collect info needed to debug any issues
you backed up your old firmware before flashing the latest/greatest, right?
can confirm here. no issues in dmesg, very odd. was expecting ACPI errors.
reverting PCO to 2509.4 until I can identify and resolve the issue
I didn’t backup the previous firmware which was irresponsible of me, but I do have the stock firmware.
Here’s cbmem.log: https://drive.google.com/file/d/1QYGg4b2u12404ThzS0ftv4JweyH0c2ZT/view?usp=sharing
I also found some errors with journalctl -b -p 3 which might be relevant:
Jan 14 12:22:52 c13yoga bootctl[334]:  Mount point '/boot' which backs the random seed file is world accessible, which is a security hole!
Jan 14 12:22:52 c13yoga bootctl[334]: Random seed file '/boot/loader/random-seed' is world accessible, which is a security hole!
Jan 14 12:22:53 c13yoga kernel: acp3x-alc5682-max98357 AMDI5682:00: ASoC: driver name too long 'acp3xalc5682m98357' -> 'acp3xalc5682m98'
Jan 14 12:22:58 c13yoga NetworkManager[358]: <error> [1768393378.2068] iwd-manager[0x55801e8a6450]: IWD device named wlan0 is not a Wifi device
Jan 14 12:23:24 c13yoga gdm-password][1557]: gkr-pam: unable to locate daemon control file
Jan 14 12:23:43 c13yoga kernel: elan_i2c i2c-ELAN0000:00: reading cmd (0x0307) fail.
Jan 14 12:23:43 c13yoga kernel: elan_i2c i2c-ELAN0000:00: failed to read current power state: -121
Jan 14 12:23:43 c13yoga kernel: elan_i2c i2c-ELAN0000:00: failed to set power off: -121
Jan 14 12:23:43 c13yoga kernel: elan_i2c i2c-ELAN0000:00: PM: dpm_run_callback(): acpi_subsys_suspend returns -121
Jan 14 12:23:43 c13yoga kernel: elan_i2c i2c-ELAN0000:00: PM: failed to suspend async: error -121
Jan 14 12:23:43 c13yoga kernel: PM: Some devices failed to suspend, or early wake event detected
Jan 14 12:23:44 c13yoga kernel: amdgpu 0000:04:00.0: amdgpu: [drm] *ERROR* Unsupported suspend state 2
Jan 14 12:23:44 c13yoga kernel: amdgpu 0000:04:00.0: PM: pci_pm_suspend(): amdgpu_pmops_suspend [amdgpu] returns -22
Jan 14 12:23:44 c13yoga kernel: amdgpu 0000:04:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -22
Jan 14 12:23:44 c13yoga kernel: amdgpu 0000:04:00.0: PM: failed to suspend async: error -22
Jan 14 12:23:44 c13yoga kernel: elan_i2c i2c-ELAN0000:00: reading cmd (0x0307) fail.
Jan 14 12:23:44 c13yoga kernel: elan_i2c i2c-ELAN0000:00: failed to read current power state: -121
Jan 14 12:23:44 c13yoga kernel: elan_i2c i2c-ELAN0000:00: failed to set power off: -121
Jan 14 12:23:44 c13yoga kernel: elan_i2c i2c-ELAN0000:00: PM: dpm_run_callback(): acpi_subsys_suspend returns -121
Jan 14 12:23:44 c13yoga kernel: elan_i2c i2c-ELAN0000:00: PM: failed to suspend async: error -121
Jan 14 12:23:44 c13yoga kernel: PM: Some devices failed to suspend, or early wake event detected
Jan 14 12:23:44 c13yoga kernel: amdgpu 0000:04:00.0: amdgpu: Power consumption will be higher as BIOS has not been configured for suspend-to-idle.
                                 To use suspend-to-idle change the sleep mode in BIOS setup.
Jan 14 12:23:44 c13yoga systemd-sleep[3715]: Failed to put system to sleep. System resumed again: Remote I/O error
Jan 14 12:23:44 c13yoga systemd[1]: Failed to start System Suspend.
Suspend also does not work on linux.
I reverted the script to use the 2509.4 firmware, so you can re-flash that way while I investigate
Fixed in 2512.1
Title: Lenovo ThinkPad C13 Yoga (Morphius) — Touchscreen Code 10 on Windows 11, CoolStar Driver Not Activating
Hello everyone,
I’m trying to restore the touchscreen and pen functionality on my Lenovo ThinkPad C13 Yoga Chromebook (board: Morphius), running Windows 11 Pro.
My system:
  • Laptop: Lenovo ThinkPad C13 Yoga Chromebook
  • Board: Morphius
  • OS: Windows 11 Pro, build 26100
  • Firmware: MrChromebox 2405.0
The problem:
My touchscreen does not work. In Device Manager, the I2C HID Device shows Code 10:
“A request for the HID descriptor failed. This typically occurs when there is a problem with the device firmware.”
Device details:
  • Hardware ID: ACPI\VEN_GDIX&DEV_0000
  • Device ID: ACPI\GDIX0000
  • Parent: ACPI\AMDI0010\2
  • Current driver: Microsoft hidi2c.inf
  • Driver version: 10.0.26100.1150
I have installed the CoolStar CrosTouchScreen driver packages (version 2.9.5.0), but Windows continues to use the Microsoft driver. The touchscreen worked previously under Windows 10, but stopped working after I installed Windows 11 or possibly after removing some programs.
I found a Morphius touchscreen discussion mentioning that an issue was fixed in firmware 2512.1.
My questions:
  1. Is there a compatible CoolStar driver for the Goodix GDIX0000 touchscreen?
  2. Is the HID descriptor failure related to firmware compatibility?
  3. Would updating from MrChromebox firmware 2405.0 to a newer version help?
  4. What is the safest way to troubleshoot this without a USB drive or another computer?
I would appreciate any guidance. I want to restore both touchscreen and pen functionality without risking my laptop. Kindly advice me what can i do ?
Please anyone solve my problem, I am a student and I need it.
Thank you!
I2C HID devices use the standard Windows drivers, not coolstar’s. coolstar’s drivers are for non-HID I2C devices only.
flash to the latest firmware, I have zero time to troubleshoot an issue from firmware that’s over two years old.
