Touchpad and touchscreen not working on Lenovo Ideapad 14 Flex 5
Hi guys, just finished installing windows 11 and the drivers as instructed but somehow still can’t make the touchpad and the touchscreen work. Any idea how to fix it?
Laptop is Lenovo Ideapad 14 5i with i5 12th gen, codename Taeko.
Thanks
Make sure you have the dptf and touchscreen drivers downloaded and installed that are linked in coolstars guide
do make sure you are connected to the internet when installing the drivers
I did that but still no luck. Any other things that I should try?
Are you using full rom or rw legacy?
Full rom. I actually tried reinstalling the windows did all the drivers again and now the touchscreen works, but touchpad still doesn’t.
Edit: finally got it working, just need to tinker something in the device manager.
Now the only things that don’t work is the USB-Cs and micro sd card reader. Do I need to pay for the driver or is it supposed to be working when I installed the chipset drivers?
Can I ask what you did to fix it? Facing a similar issue myself, getting a “STATUS_DEVICE_POWER_FAILURE” error on the device manager for the touchpad
Hello, how did you fix touchpad?
