The audio driver is not work on HP Elite C1030;while my OS is debian 12
the audio driver is not work on HP Elite C1030;while my OS is debian 12
https://drive.google.com/file/d/1Uz7cACfx7C5mRRknB9_9u64-9aPQNEeE/view?usp=drive_linkhere is my debug fie
what is the output of uname -a?
Linux MiWiFi-R4CM-srv 6.6.58-chrultrabook #1 SMP PREEMPT_DYNAMIC Sat Oct 26 13:45:57 UTC 2024 x86_64 GNU/Linux
hmm ok your kernel looks good. Do you have a sof device when you press f6 in alsamixer?
Hello, same issue on debian 12 (Distro Q4OS) on Asus C302 (cave)
hmm. I looked at @half 's dmesg and it seems like the kernel side is working fine (I get the same sof errors on tigerlake but audio works fine). But the card seems to default to disabled. If you have a sof device in alsamixer this is probably the case. You probably just need to enable/unmute the device in pavucontrol or the pipewire equivalent (I just used the one built into kde).
