Teliks360 / ASUS Chromebook CR1104FTA sound issue
  • Device: Teliks360
  • OS: Windows 11 Pro 25H2 26200.8246
  • Firmware Version: MrChromebox-2603.1-7-gd6b12c8a5a1-dirty 04/22/2026
  • Internal storage type: eMMC
Speakers do not work after sleep/hibernate.
Restart device, play any kind of sound, sounds comes through speakers fine.
Place device into sleep or hibernation, and start it up again.
Sound no longer comes through speakers, although in the mixer/settings, Windows thinks it is still playing sound.
Expect to continue to hear sound through the speakers.
I seem to have found a solution, in case it helps anyone else. In device manager, under View - Devices by connection, when I disable and re-enable the device Realtek ALC5650 I2S Audio, the audio comes back. It seems to always stay on if I leave the device disabled.
Same symptom on an ASUS CX1405CTA (teltic, N50), Windows 10 22H2, CoolStar SOF Audio 1.0.5-1, firmware MrChromebox-2609.2. Sound works after a restart, but after sleep the speakers are silent while Windows still shows the meter moving. Device Manager shows the driver as working properly. I tried disabling and enabling the driver and the Speakers endpoint, and restarting Windows Audio. None of it helped. Only a full restart does. Fast Startup caused the same thing on a cold start until I turned it off. Devices by connection shows only the speakers and microphone endpoints, with no separate codec device. Has anyone found a fix?
For my device, running the following two commands in cmd seems to bring it back to life, I have this saved as a bat file on my desktop to run when the issue happens:
pnputil /disable-device ACPI\10EC5650\0
pnputil /enable-device ACPI\10EC5650\0
Sometimes leaving the device disabled makes the problem go away too.
