Support for HP Chromebook x360 14b - Joxer
Hello. I need help to make a modding to HP Chromebook x360 14b, Intel N100 processor and board name Joxer. I’ve been searching for support of this model and I got nothing. I wanna know how to disable WP, I also need to know if this device is Full UEFI ROM compatible and where to find the drivers for Windows.
where exactly have you been searching?
it’s listed on:
and
Thanks a lot!!! Finally I found it. I started to look it for in coolstar.org. I selected HP, Intel N100, but my model was not on results. Thanks to you, now I know the compatibility, but I still need the drivers and the exact method to remove the WP. Should I use another model as reference? For example, Fortis G10? There’s not a page with full support for Joxer, but Fortis G10 share the same mark and processor. Thanks for your patience.
Finally I did it. I remove the WP using the CR50/Ti50. It seems to be the same. Most of the drivers I was able to install it from Snappy and for the EC Driver I use the HP Fortis G10. I really hope this information can help someone.
