Support for Another Chromebook
  • Device: Lenovo Chromebook Duet 11m889
  • Model: CIRI-LDPJ
  • OS: ChromeOS
  • Firmware Type: Stock
  • Firmware Version: ?
It says to email but I couldn’t find one. I’d like support for this chromebook so that I might try and start learning distros using an old laptop.
that’s an ARM-based device, so your options are significantly limited in comparison to an Intel/AMD one. There’s no custom firmware and no support for it from the MrChromebox project.
Thanks for ur response! Cadmium it is, then
