I got Ubuntu working recently, but not the audio. I tried using the script, but there was no sound, even after running the script. (Still said "Dummy Output, and no audio inputs or outputs were listed in the settings.) I was gonna switch to 25 but found out about the problems with non-LTS releases. I then found out you could use a newer kernel, so I did that and reran the script that time, but it still failed, despite showing success. (See above) I learned how to get troubleshooting help with the script provided on WeirdTreeThing’s post, so I ran it and here are the results, all on my Google Drive. The Goods! I am running a Chromebook+ with the model name YAVIKS. Ask for info as needed. (Last post deleted to test if the deletion feature would ask if you are sure. It didn’t so I’m rewriting this and making it a bit shorter and all the more easier to understand.)
