[SOLVED] Boot Issues with EndeavourOS on Lenovo Chromebook 3i-15 (Full EFI)
Hi everyone,
I have a Lenovo Chromebook 3i-15 with full EFI already installed, and I recently installed EndeavourOS (an Arch-based distro). The installation went smoothly, but I’m having issues during boot.
When I power it on, it often freezes during the boot process. The text logs appear, but at some point, it just stops, and the CPU heats up a lot. However, after 3 or 4 restarts, the computer starts working normally again.
I’m not sure how to troubleshoot or fix this issue, so I could really use some help.
Thanks in advance!
Solved:
4.41. https://wiki.archlinux.org/title/Chrome_OS_devices#Installation
those instructions are essentially the same as the chrultrabook docs, what was your issue exactly?
I don’t know why, but sometimes when I boot up the Chromebook, it gets stuck on loading. Maybe it’s something related to RF kills or something else that causes the CPU to heat up.
I tried the fix you suggested from the Arch Wiki, and it worked for a short time, but now it’s not working anymore.
Any other ideas or suggestions?
I don’t know what you mean by this
My bad, i wrote in wrong piace. I had to write it in the arch wiki For another computer.
however the problem remains:
Every time I turn on the PC it freezes on startup. the only thing that allows me to start the chromebook is resetting it several times. I can’t figure out what the problem is.Possible missing drivers?
board name?
HWID: BLIPPER
os: endeavour
I’m having the same issue and my previous fix was to use the linux-lts kernel.
That doesn’t work anymore, have you found a fix yet?
