Setting GBB flags on ARM Chromebooks?
On my second x86 chrultrabook loving life. Feeling the need to tinker once again…
Recently picked up a used ARM detachable 2-1 Lenovo Duet 3 (google-wormdingler) that is supported by Postmarket OS. Does the FW utility script work on it also to set the GBB flags? Alternately per postmarket OS, I can do it via command line.
Being mostly a tablet, I was trying to avoid opening it up but watching it a quick YT video looks like its just held in with clips no glue. Battery disconnection might be easier than original assumed so might go that route. Do these ARM devices also work with suzzy Q cables?
Postmarket OS doesn’t quite have the same community support so my apologies for posting this here.
just set the GBB flags via command line from ChromeOS before installing anything else. My script won’t work on ARM devices.
Thanks. Do you know if the suzzy q cables work for ARM devices also?
PS - Appreciate everything you have done for the community. Sent a couple bucks you way via PayPal. :pray:
Arm devices support CCD the same as x86 devices. as long as the device has a GSC, which yours does.
how do you do that and what exactly do you type in I’m on debian 12 arm64 on Lenovo IdeaPad slim 3
There is some good guides on postmarket OS wiki. I would defer there for more ARM info and how to.
