Hello! I am trying to install Debian on my Asus Chromebook (c202sa) running the Mrchromebox. Tech Full UEFI but, the SdDxe driver will not start preventing me from using the SD card slot (I don’t have a thumb drive) | After running drivers in the UEFi Shell the misbehaving driver is called Edkii SD Memory Card Device Driver with DRV being 6D(unsure if this issue is caused by me formatting the built-in EMMC )
Note; Before formatting the EMMC I was able to get into Arch Linux but now I’m trying to switch to Debian, also I DO have a Windows 8.1 installer that I put on the EMMC beforehand | I also DO not have a bootable OS (besides for the windows 8.1 installer)
why do you believe this driver is not starting?
Because the SD card does not show up in the Shell, or the select file to boot from screen, and when running drivers in the Shell the SdDxe driver does not show it is assigned to any device
I’m confused as to why you think it isn’t starting, vs ran and failed to enumerate any devices on the system.
there’s unfortunately no way to debug this, short of soldering a servo interface onto the board, and running a debug build to see what’s going on.
I don’t think it’s starting because the SDdxe Driver isn’t even in the list
that’s not indicating what you think it is, and my assessment above stands.
