sasuke
October 5, 2026, 2:16pm
1
Device : [SASUKE]
OS : [debian]
Firmware Type : [UEFI Full ROM]
Firmware Version : [latest 2609.1 Release ]
Internal storage type : [eMMC]
It seems that this issue is still present. Actually, it may have gotten worse, since the boot delay got even longer than on 2606 or 2603.
opened 01:30PM - 07 Mar 26 UTC
## Device Info
- **Board:** Google Sasuke (Dedede family)
- **CPU:** Intel Celer… on N4500 (Jasper Lake A0)
- **Firmware:** MrChromebox-2512.2 (UEFI Full ROM)
- **OS:** Ubuntu 24.04.4 LTS, kernel 6.17.0-14-generic
- **SD card:** 128GB Samsung FD4Q9 (SDXC, UHS-I SDR104)
## Problem
With a microSD card inserted in the on-board slot (PCI 00:14.5, Intel 8086:4df8), boot takes **2+ minutes** from power-on to GRUB/LUKS prompt. With the SD card removed, the same boot takes **~17 seconds**.
The entire 140+ second delay occurs during the EDK2/UEFI phase — coreboot itself completes in ~1.26 seconds (see cbmem below).
## Reproduction
1. Insert any SDXC card into the on-board microSD slot
2. Power on
3. Observe 2+ minute boot (vs ~17s without card)
The card is not being booted from — it contains a single LUKS-encrypted ext4 partition. The delay is purely from enumeration.
## Kernel dmesg (after EDK2 hands off)
The kernel sees the SD controller early but the card itself doesn't appear until ~230s:
[ 0.648] sdhci-pci 0000:00:14.5: SDHCI controller found [8086:4df8] (rev 1)
[ 0.649] mmc0: SDHCI controller on PCI [0000:00:14.5] using ADMA 64-bit
[230.929] mmc0: non-supported SD ext reg layout
[230.929] mmc0: new UHS-I speed SDR104 SDXC card at address 0001
[230.930] mmcblk0: mmc0:0001 FD4Q9 119 GiB
[370.175] mmc0: card 0001 removed
[377.719] mmc0: error -123 whilst initialising SD card
[379.191] mmc0: non-supported SD ext reg layout
[379.191] mmc0: new UHS-I speed SDR104 SDXC card at address 0001
[389.675] mmc0: Timeout waiting for hardware interrupt.
The card enumerates, then disconnects/reconnects with errors — suggesting EDK2 leaves the SDHCI controller in an odd state.
## cbmem -t (coreboot timing)
Coreboot completes in 1.26s total:
48 entries total:
0:1st timestamp 35,102 (0)
11:start of bootblock 54,404 (19,301)
12:end of bootblock 58,822 (4,417)
1:start of romstage 60,179
951:returning from FspMemoryInit 162,622 (70,813)
955:returning from FspSiliconInit 417,425 (114,198)
70:device setup done 506,433 (82,440)
16:finished LZMA decompress (ignore for x86) 1,259,490 (746,652)
99:selfboot jump 1,260,835 (182)
Total Time: 1,225,710
## What I've tried
- **Disabled Intel ME** in Platform Setup Menu → no effect on boot time
- **Cleaned NVRAM / boot entries** → no effect
- **Set boot timeout to 0** → no effect
- **Checked for Fast Boot option** → not available in EDK2 setup menu
- **Different SD cards** → same behavior
## Workaround
Remove SD card before boot, hot-insert after login. I've set up a udev+systemd service to auto-unlock/mount the LUKS partition on insertion.
## Relation to #776
Issue #776 reports that the on-board SD slot isn't recognized in the EDK2 boot menu on Sasuke. My issue is related but distinct: the SD card is never bootable from EDK2, but its presence during boot causes a ~140s delay in the EDK2 phase before handing off to the OS bootloader.
Both issues point to problematic SDHCI controller handling (8086:4df8) in EDK2 on Jasper Lake Dedede boards.
Insert a SD card into the powered-off device
Start it
Wait about 3 to 4 minutes until the boot screen finally appears.
Without the SD card, the startup takes less than 10 seconds.
the issue is still open on github, because it’s a known issue.
sasuke
October 5, 2026, 2:19pm
3
Strangely enough, I remember that 3 main versions ago, the device would start up normally.
3 main versions ago was 3 stable tags (or more) of edk2 ago. possible something changed there.
Do you mean 2512 or 2603?
sasuke
October 5, 2026, 2:31pm
6
It must’ve been the 2603.1 Release I remember that it was present on 2603.0
sasuke
October 5, 2026, 2:46pm
7
Given that this is a “Samsung Galaxy Chromebook Go” with some measly 64GB built-in storage capacity, and no expansion slots whatsoever, the SD card is kind of necessary.
only so many hours in a day, and only so much time I can spend fixing bugs in another project for free
