Sd card not working on Samsung Chromebook 3 (CELES)
I’m running Lubuntu on it right now. It works great out of the box. Audio and camera worked out of the box too. I had to install a patch for the function keys to work (The only ones that seemed to be fixed were the audio ones but it’s not a big deal). The only thing that doesn’t work is the sd card slot. I was wondering if there was a patch or something that could fix it.
Good luck this is what the docs say about your chromebook.
  • Samsung Chromebook 3 (CELES): Numerous hardware bugs that make it difficult to use.
Still hope you can get it fixed.
Did you test under another Linux distribution other than something Ubuntu based (which isn’t even supported by us)
Try testing in something like fedora or debian
