Samsung chromebook go hwid help :(
Hi yesterday i use mrchromebox’s script and its good. But my hwid changed sasuke 123-ABC-456-XYZ. Please if anyone know samsung chromebook go hwid tell me and hrlp me :(. Thank you
serious question here: how can make it more clear that you need to backup your firmware and keep it in a safe place?
that’s not the full HWID
Oh I thought the newer Chromebooks only used the 4 letters now - so you can no longer get the HWID from recovery?
you can, you just need to show more details to see it
Here is what mine says:
SASUKE-WCLL C6C-A2A-F4F-W7A-A2M
Thank you. Open chrome type chrome://system and find hwid
Thanks i will try it
You’re right, I hurried. :frowning:
By the way, if you want Linux etc., this is WP. Paste solder or a metal piece here, short circuit it and start the mrchromebox script. After the process is completed, cancel the short circuit when the device turns off. It’s that simple. But then I couldn’t activate WP… its giving battery error but this device cr50 protection.
One question whats your model number chromebook go ? its under the chromebook My model: XE345XDA
model is irrelevant, what is your board name?
Its sasuke (samsung chromebook go) its not 11". 14" screen…
ok, have added the image to my site for SASUKE.
that leaves SASUKETTE still unknown
Ok. I tried lot of linix distros. Pop os arch mint etc. My best experience and most fast distro is linux mint mate. Mint cinnamon, and pop os. Those who try one of these will not regret it. I haven’t tried the hwid of the friend who wrote above yet, currently Linux Mint Mate is installed. So do you have hwid for sasuke or help me ? Thanks
what exactly are you asking for?
Thank you my friend. Its work. Now chromebook begin update and no error or issue. Very thanks… :slight_smile:
Its worked mrchromebox. But wp disabled again. I cant do that wp enabled.
