RUDRIKS (Acer Spin 512) — WP jumper / flash chip location? (enrolled, battery-disconnect didn't disable WP)
Board: RUDRIKS — Acer Chromebook Spin 512, mainboard DAZDKMB16A0 REV:A (manufactured 2025). Listed on MrChromebox as UEFI Full ROM supported.
Goal: flash UEFI Full ROM and install Linux.
The catch — it’s enterprise-enrolled. Bought used; the enrolling org no longer exists, so it can’t be un-enrolled from the admin console (I own the device). block_devmode is set — “entering developer mode is not allowed.” The SuzyQ / CCD write-protect method is out, since the GSC refuses to disable WP while enrolled. And I fully removed the battery and ran on the charger — dev mode is STILL blocked, so battery-disconnect didn’t disable WP either. (From what I’ve read this board normally uses battery-disconnect for WP and has no WP jumper.)
My questions: Has anyone flashed a RUDRIKS / Acer Spin 512 (Alder Lake-N)? Since it’s enrolled and battery-disconnect doesn’t drop WP (and there’s no jumper), is external flashing (a CH341A clip on the SPI chip) the only remaining route? And if so, where is the SPI flash chip on this board, and what package is it?
Happy to add board photos. Thanks!
you’re not going to bypass enrollment on Ti50-based boards (which all Alderlake-N boards are). Even if you flash the device manually, AP-RO verification is still set, and can’t be disabled while the device is managed
