didn’t really know where to post this, but i have had an issue with inverted screen rotation on Linux with my HP Chromebook 14 (ca-0090wm) for over a year and i have finally solved it.
instructions (mostly terminal commands):
open terminal
cd /lib/udev/hwdb.d
sudo nano 60-sensor-local.hwdb (not necessary to create a separate file but makes it easier to work with)
input this exactly how it is formatted here (without quotes, also don’t try doing this by hand lol)
“sensor:modalias:platform:cros-ec-accel:dmi*:svnGoogle*:pnBlooguard:*
ACCEL_MOUNT_MATRIX=-1, 0, 0; 0, -1, 0; 0, 0, -1”
save the file with ctrl+x, run sudo udevadm hwdb --update, reboot, and enjoy the fixed screen rotation.
if your chromebook has the same exact issue you can try replacing Blooguard with your model to see if it works or try a different value from the existing set of Chromebook models included here, after all i just copied that from the Inspiron 2-in-1 and changed the model name.
cheers, hope this helps someone!
edit: i guess this has been fixed in newer kernels, but i’m running 22.04.
