Redrix (HP Elite Dragonfly Chromebook) — Fedora 43 Issues, Findings & Requests for Guidance
  • Device: Redrix (Alder Lake/Brya family), Intel Core i7-1255U
  • OS: Linux, Fedora 43 Workstation, GNOME, Wayland, PipeWire
  • Kernel: 6.18.16-200.fc43.x86_64
  • Firmware Version: MrChromebox-2512.2 (01/25/2026)
  • Internal storage type: NVMe
Full disclosure, I have been using AI, along with lots of searching, to assist with this project so far, and even to summarize this post. I am a noob, so don’t hesitate to treat me as such. Additionally, it mostly just works with Fedora Workstation. I initially tried Manjaro based Big Linux, as that is what I run on my desktop, but it was far more cantankerous trying to set everything up.
I’ve been running Fedora 43 on my Redrix board for a short while and have made solid progress getting the system functional. I’m posting both to share what’s working and to seek guidance on several unresolved issues. I’ve done my best to document everything thoroughly including relevant log output. Also, for what it’s worth, it is funcional as is, just with caveats (which I assume is expected).
What’s Working (with fixes applied)
Suspend/sleep enters S3 deep sleep reliably after applying three fixes: the mem_sleep_default=deep kernel parameter, a systemd service to unload cros_ec_lpcs, cros_ec_keyb, and cros_ec_typec before sleep, and blacklisting the IPU6 camera modules. Without these the system would wake immediately after lid close.
Audio works correctly using the Pro Audio profile via WirePlumber. The accelerometer works and a manual tablet mode toggle script works for disabling the keyboard/touchpad and enabling auto-rotate. I get a notification popup in Fedora saying tablet/laptop mode when I run the script. Has anyone gotten tablet mode to work automatically when the lid is flipped?
Unresolved Issue #1 — xHCI Reset Loop During Suspend / Battery Drain
This is my most significant issue. While the system does enter S3, it never truly sleeps. The kernel log shows the xHCI controller resetting on a loop approximately every 20-30 seconds throughout the entire suspend period:
xhci_hcd 0000:00:0d.0: xHC error in resume, USBSTS 0x401, Reinit
usb usb1: root hub lost power or was reset
usb usb2: root hub lost power or was reset
The observable symptom is that the power button indicator light and keyboard backlight cycle on and off throughout suspend — on for ~20 seconds, off for ~1 second, repeat. This results in approximately 5-6% battery drain per hour in suspend, compared to days of standby on ChromeOS.This is after applying a fix from this thread here.
I will add, when I initially had Big Linux installed, Claude and I got the battery drain down to approximately 1% per hour.
I (AI) understand(s) ChromeOS uses S0ix which MrChromebox may not fully support on Redrix. Is this a known issue? Is there any workaround short of Submarine firmware?
Unresolved Issue #2 — Double Login on Resume
After waking from suspend, GDM presents the login screen. I enter my password successfully, but the session immediately collapses and GDM presents the login screen a second time. This happens on the majority of resumes. The timing varies — sometimes it happens before I even finish typing my password the first time, other times it takes up to ~20 seconds after the first successful login.
Relevant log entries around the event:
gnome-shell[2939]: Cursor update failed: drmModeAtomicCommit: Invalid argument
systemd-logind[936]: Delay lock is active (UID 1000/wadem, PID 2939/gnome-shell) but inhibitor timeout is reached.
Steps already taken with no resolution: masked fprintd, removed with-fingerprint from authselect, increased InhibitDelayMaxSec, applied and reverted i915.enable_psr=0 i915.enable_fbc=1. The drmModeAtomicCommit: Invalid argument error appears consistently before each double-login event. Any guidance appreciated.
Unresolved Issue #3 — Camera
IPU6 modules are currently blacklisted to prevent them from blocking suspend. I’m aware a fix exists but haven’t applied it yet. Has anyone confirmed this works on Redrix specifically? Any caveats?
Additional Issue — Keyboard Backlight Lost After Extended Poweroff
On two consecutive mornings, the keyboard backlight has failed to initialize after the machine sitting powered off overnight. Symptoms: the brightness indicator/gauge appears when pressing the physical backlight key, showing the level as empty/off. Adjusting via GNOME quick settings has no effect. The sysfs value (/sys/class/leds/chromeos::kbd_backlight/brightness) reports the correct brightness value (e.g. 100) but the keys remain unlit.
A standard reboot does not resolve it. The only fix found so far is a deliberate full power off (sudo poweroff), waiting ~30 seconds, then booting back up.
This only occurs after an extended cold poweroff (overnight). It does not occur after a normal reboot or short poweroff.
Pending / Not Yet Configured
  • Volume rocker — not yet configured, open to suggestions
  • Keyboard backlight timeout — not yet configured
  • Caps Lock remapping — planning to use GNOME Tweaks
  • Function keys — planning to use keyd
  • Microphone — just now tested, not working, open to suggestions
Submarine Firmware
I’ve been researching Submarine as an alternative to MrChromebox, particularly given the suspend and battery drain issues. The Ctrl+D on every boot is a deterrent but I understand it may resolve the S0ix and EC power management issues. Has anyone on Redrix specifically made the switch and can speak to whether it resolves the xHCI reset loop and battery drain? Any other tradeoffs worth knowing about?
I have read the thread on here, linked below, but can anyone confirm that everything is actually working as the OP claims.
References
Summary
  1. Is the xHCI reset loop during S3 suspend a known issue on Redrix/Brya with MrChromebox firmware, and is there any software workaround short of switching to Submarine?
  2. Has anyone experienced the double-login on resume with GNOME/GDM on Redrix? The drmModeAtomicCommit: Invalid argument error appears consistently before each occurrence — is this a known issue and is there a fix?
  3. Has anyone successfully gotten the camera working on Redrix via the chromebook-linux-audio script with IPU6 modules, and are there any caveats?
  4. For those who have switched to Submarine firmware on Redrix — does it resolve the S0ix/battery drain and xHCI issues? Any unexpected tradeoffs beyond the Ctrl+D on every boot?
  5. The MrChromebox firmware utility script fails on Fedora 43 even with iomem=relaxed added to kernel parameters and secure boot disabled. Is running from a Live USB the only option for firmware updates on this distro, or is there another workaround? UPDATE: iomem=relaxed didn’t take the first time, it is now working!
    Note — Kernel Oops with iomem=relaxed
    In order to run the MrChromebox firmware utility script on Fedora 43, iomem=relaxed needs to be added to kernel parameters. While this parameter was active, a kernel oops was recorded:
    Oops: general protection fault, probably for non-canonical address
    0x3c4b2b7eff4c948a: 0000 [#1] SMP NOPTI
    crash_function: blocking_notifier_chain_unregister
    It was a single occurrence, timed to when the firmware script was running. iomem=relaxed was removed immediately after retrieving the firmware version info. No further oops events have occurred since removal.
  6. Any recommendations for configuring the volume rocker on Redrix under Linux?
  7. Has anyone gotten tablet mode to work automatically by just flipping the lid over into tablet mode?
I don’t have much to contribute about Fedora/Linux quirks as I daily drive Windows on my Redrix, but here’s one thing I may help:
The tablet mode sensor was disabled in 2512 releases for brya-based boards, which include Redrix: accelerometer is not working in redrix · Issue #879 · MrChromebox/firmware · GitHub. If you’re running one of those releases, that’s probably your only problem.
I don’t know if MrChromebox already updated the builds offered by the firmware utility script, if he did then updating should be all you need to get tablet mode working. Otherwise you may have to manually install the firmware from the issue above.
I can also tell that the sleep issue doesn’t exist in Windows, mine uses up about 150mW of power during S3 (S0ix is disabled in mine), and can sleep for multiple days without worry. The power LED stays completely off during S3 (strangely so, yes, but it is indeed sleeping and not hibernated or off, as it wakes up imediatelly on a wake event instead of booting from disk. In fact, S4 is disabled in the OS).
So the firmware can reliably sleep just fine in S3 at very low power and the issue should be fixable in Linux side. Linux is very flexible, after all.
Hmm, I read through that thread and seen you confirmed the link that Mr Chromebox posted did fix your issue, both for Fedora 43 and Windows. I also noticed the date of those posts are Feb 02. The firmware I am on is 2512.2 (01/25/2026). I have not tried installing that fix as my accelerometer is working, so I’m not sure we share the same root cause. My specific issue is activating tablet mode via lid flip.
My system can see the lid switch (I think), but the lid switch isn’t firing for some reason (might be watching the wrong switch). Additionally, after forcing tablet mode via the terminal, my touch pad, physical keyboard and backlighting would not disable. Scaling and screen auto rotation work excellent for me. That’s why I have a script to toggle tablet mode on/off, and it also disables the physical keyboard, backlight, touchpad, and also toggles the virtual keyboard (OSK) on.
Again, I am as green as can be, but I have dabbled over the years. That said, I am leaning on Claude pretty heavitly and Google-ing (or DuckDuckGo-ing).
I originally installed Manjaro based Big Linux and most everything was horrible. But, the lid switch for tablet mode did fire on Big Linux. We had to write scripts to disable keyboard and such as well, but the script would automatically run with the lid flipped (just like tablet mode should). Rotation didn’t work and scaling was horrible, but the lid switch was firing. This is when I first stumbled across the thread you linked. I was going to apply that fix, but Big Linux needed so much work that I decided to jump to Fedora instead, as Gnome seems to be better optimized for touch screens.
This is where I am totally lost, and the main reason why I decided to reach out for some guidance. With the Big Linux install we had to write a script to disable bluetooth on sleep (and re-enable on wake) because bluetooth wouldn’t let the computer enter sleep mode and hogged 72% battery in 6.5 hours overnight. After that, the computer used around 7% battery over 7.5 to 8 hours (exact time eludes me) the following night.
I did apply a fix from the suspend thread that I linked in my original post and it has helped tremendously with the Fedora sleep issue. Fedora is sleeping fine and I have no failed sleep sessions, as far as I can tell. Something is cycling the keyboard backlight on for 20s and off for about a full second, and then repeating that pattern the entire time it is sleeping. Turning the keyboard backlight off before closing the lid does not chage this behavior either.
I appreciate your reply nonetheless. Also, do you have any knowledge of, or experience with, the Submarine firmware in the other thread I linked? It looks too good to be true is why I am hesitant. I am strongly considering giving it a go though.
Still worth a try. I’m pretty sure the ‘accelerometer not working’ in the issue was actually a consequence of the lid switch, as, by default, the OSes only answer to rotation when in tablet mode.
Then, when you manually force-enabled tablet mode, rotation started working because the accelerometer itself wasn’t really unavailable, the OS just ignored it because one wouldn’t want to rotate a clamshell laptop.
The fact you say the sensor works in Big Linux puzzles me though. For sure the public 2512.2 release had it not exposed, maybe that distro accesses it some other way than relying on firmware?
I never tried Submarine as my original intent for this device always was to put Windows on it.
But you mention that “The Ctrl+D on every boot is a deterrent”, you should be able to disable this on Google’s firmware by changing the GBB flags with MrChromebox’s script, you can set it to boot to AltFw by default with short timeout. This requires disabling write protect, but this won’t be an issue for you since you’re already on a Redrix with Full ROM so you probably have a SuzyQ?
Which means that there’s a chance Submarine might be your solution indeed.
Huh… That’s a bit weird. I have a brya-based chromebook (crota360) and all the major linux distributions as well as Windows can’t see the sensor hub on my device and it is treated as a clamshell.
I decided to give Submarine a test spin. It does work better out of the box and requires fewer fixes I guess. I’ll probably stick with it. Tablet mode is a little wonky but generally works without any fixes appled. I’ll probably tinker with it a bit.
Last night I reverted back to stock and didn’t install Submarine/Ultramarine on it until this morning. I noticed that the power led indicator, while on chrome os, doesn’t stay illuminated either. The indicator on my stock HP Elite C1030 slowly pulses while sleeping. Just thought I’d mention it.
UPDATE:
From 10:15 PM to 6:05 AM my battery went from 57% to 54% while sleeping. This is using the Submarine method linked in my original post. For reference, the night before when I went back to full stock, from 12:30 AM to 7:42 AM it went from 100% to 98% while sleeping.
If you’re interested, here is an AI summary of how we got tablet mode functioning on Manjaro based Big Linux.
Sure! Here’s a comprehensive summary of everything we did to get tablet mode working on the HP Elite Dragonfly Chromebook (Redrix) under Big Linux/Manjaro KDE:
HP Elite Dragonfly Chromebook (Redrix) - Tablet Mode Fix on Manjaro/Big Linux
Hardware confirmed working:
  • cros-ec-accel (x2) — accelerometers
  • cros-ec-lid-angle — lid angle sensor
  • cros-ec-gyro — gyroscope
  • cros-ec-light — ambient light sensor
  • SW_TABLET_MODE switch via /dev/input/event4 (GOOG0007)
Problem: Screen turning off when folding into tablet/tent mode.
Root cause: KWin was detecting the SW_TABLET_MODE input switch and turning off the internal display.
Solution 1: Block KWin from accessing the tablet mode switch
Create /etc/udev/rules.d/99-tablet-mode.rules:
SUBSYSTEM=="input", KERNEL=="event4", OPTIONS+="static_node=input/event4", TAG+="uaccess", MODE="0600", OWNER="root"
Reload udev:
sudo udevadm control --reload-rules
sudo udevadm trigger
sudo reboot
This restricts the tablet mode switch to root only, preventing KWin from reading it directly while allowing our root systemd service to handle it.
Problem: Keyboard backlight staying on in tablet/tent mode, and display needed to be re-enabled after KWin turns it off.
Solution 2: Tablet Mode Handler Script
Install evtest:
sudo pacman -S evtest
Create /usr/local/bin/tablet-mode-handler.sh:
#!/bin/bash
BACKLIGHT=/sys/class/leds/chromeos::kbd_backlight/brightness
USER_NAME="wadem"
USER_ID=$(id -u $USER_NAME)
evtest /dev/input/event4 | while read line; do
    if echo "$line" | grep -q "SW_TABLET_MODE.*value 1"; then
        echo 0 > $BACKLIGHT
        sleep 0.5
        sudo -u $USER_NAME DISPLAY=:0 WAYLAND_DISPLAY=/run/user/$USER_ID/wayland-0 XDG_RUNTIME_DIR=/run/user/$USER_ID kscreen-doctor output.eDP-1.enable
    elif echo "$line" | grep -q "SW_TABLET_MODE.*value 0"; then
        echo 50 > $BACKLIGHT
    fi
done
Replace wadem with your username.
Make it executable:
sudo chmod +x /usr/local/bin/tablet-mode-handler.sh
Create /etc/systemd/system/tablet-mode-handler.service:
[Unit]
Description=Tablet mode handler for keyboard backlight
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/local/bin/tablet-mode-handler.sh
Restart=always
RestartSec=5
[Install]
WantedBy=multi-user.target
Enable and start:
sudo systemctl enable --now tablet-mode-handler.service
Problem: Auto-rotation not working in tablet mode.
Solution 3: Install iio-sensor-proxy
sudo pacman -S iio-sensor-proxy
iio-sensor-proxy starts automatically via D-Bus activation. This enables:
  • Screen auto-rotation via accelerometers
  • Ambient light sensor
  • Tilt detection
Verify it’s working:
monitor-sensor
Problem: Virtual keyboard not appearing when tapping text fields in tablet mode.
Solution 4: Configure Maliit Virtual Keyboard
Maliit should already be installed:
pacman -Qs maliit
If not:
sudo pacman -S maliit-framework maliit-keyboard
Configure KWin to use Maliit:
kwriteconfig6 --file ~/.config/kwinrc --group Wayland --key InputMethod /usr/share/applications/com.github.maliit.keyboard.desktop
kwriteconfig6 --file ~/.config/kwinrc --group Wayland --key VirtualKeyboardEnabled true
qdbus org.kde.KWin /KWin reconfigure
Then open System Settings → Virtual Keyboard and select Maliit.
Problem: KDE Plasma switching to tablet UI mode causing panel scaling issues when rotating.
Partial workaround: Add to ~/.config/kwinrc under [Input] section:
[Input]
TabletModeEnabled=false
Note: This is a partial fix only. The panel layout breaking on screen rotation is a known upstream KDE Plasma 6 bug with no full fix currently available.
Known remaining issues:
  • Panel layout breaks when rotating between landscape and portrait in tablet mode — upstream KDE Plasma 6 bug
  • Physical keyboard/touchpad correctly disables in tablet mode :white_check_mark:
  • Virtual keyboard works in tablet mode :white_check_mark:
  • Auto-rotation works :white_check_mark:
  • Screen stays on in tablet/tent mode :white_check_mark:
  • Keyboard backlight turns off in tablet mode :white_check_mark:
Hope this helps others on the Chrultra forum! :dragon:
Hey guys, not to revive an old post or anything to be obnoxious but I thought i’d post a reply for all those trying to find a solution.
This issue has been fixed as of the latest firmware update.
To everyone: do try updating first before doing any further tinkering. I don’t remember which version, but I believe it was fixed in all MrChromebox firmware versions 2603.x and above.
Which issue? Tablet mode, battery drain, or both?
Tablet mode initially worked like a champ with the Submarine/Ultramarine setup I linked above, but somewhere amongst some updates (I suspect kernel updates), it quit working. I have reverted back to a workaround so that it is functional. Not a big deal as it sees limited tablet use, but it is nice when needed.
I appreciate you letting me know regardless. Thank you.
I just wanted to provide an update since switching from Submarine/Ultramarine about two weeks ago. I’m back on MrChromebox, currently with Fedora Gnome. Week one I was running Ultramarine.
Suspend/sleep works excellent. I have no excessive battery drain issue, and I have not had to apply any tweaks either. Battery only drops approximately 3% - 4% overnight.
I no longer experience a double login on resume, which was only ever annoying anyhow.
Camera works but isn’t really a concern for me, so I haven’t messed with it much.
Keyboard backlighting still fails to initialize after extended periods powered off (an hour or longer, I think). A simple reboot isn’t enough to bring it back, I have to power off and use the physical power button to power back on.
Tablet mode triggers automatically now, I no longer have to use a manual toggle. I used @seaturtle tablet mode script, in the Submarine guide linked in my original post, modified for kernel 7.x and so on. This disables keyboard, keyboard backlighting, and touchpad.
I am experiencing touchpad reinit failures on resume. Rebooting fixes the issue. I experienced these with the Sub/UM setup as well. Flipping to tablet mode and back also resolves this issue (this didn’t work on Sub/UM for some reason). We created a system user service to disable/re-enable the touchpad like tablet mode does, but it runs automatically after logging in. It seems to be working well, but I did have to reboot after sitting overnight last night to get the touchpad to initialize properly. This is the first time in two weeks that flipping to tablet mode failed to fix it.
I only deployed the system user service for touchpad resume earlier yesterday and then installed keyd later last night. I suspected keyd was causing shutdown hangs that I experienced with Sub/UM and then again with MC/UM, which is partially why I went to Fedora, to see if it had something to do with any of Ultramarine’s tweaks. I still haven’t experienced and hang ups while rebooting or powering off, which I almost always experienced after extended uptime — hangs stopped when I started shutting down between sessions instead, which made us wonder if it was related to whatever corrupts touchpad state during the reinit failures. We still suspect keyd may have been the actual culprit behind those hangs, though — I only installed it again last night, so it’s too early to say whether they’ll return.
Now, it looks as if my tp resume service or keyd are having issues with my tablet mode tp reinit trick. Or, it might be coincidental. I will continue monitoring the situation for now.
Otherwise, this has been the smoothest setup yet. Battery life is noticeably better than my original MC/FG install, without any of the tuning I used to have to do. Audio, tablet mode, everything else configured and working well, and with only three fixes applied.
  1. WeirdTreeThing’s chromebook-linux-audio script
  2. ectool - lets scripts talk to the embedded controller for things like keyboard backlight control
  3. The tablet-mode-handler script — originally from seaturtle in the Submarine guide, but updated for kernel 7.x since the cros_ec_tablet module was removed
Can I get you to run the following? Sleep/suspend isn’t working on CachyOS.
  • cat /sys/class/chromeos/cros_ec/version
  • cat /sys/class/dmi/id/bios_version
  • cat /sys/power/mem_sleep
  • slp_s0_residency_usec before and after a suspend
Mine are:
❯ cat /sys/class/chromeos/cros_ec/version
RO version:    redrix_v2.0.13484-10cf54860d
RW version:    redrix_v2.0.27860-0f0590ceec
Firmware copy: RW
Build info:    redrix_v2.0.27860-0f0590ceec redrix_16238.2+tbt5 2025-10-12 21:09:39 chrultrabook
Chip vendor:   Nuvoton
Chip name:     NPCX993F
Chip revision: A.00160207
Board version: 3
❯ cat /sys/class/dmi/id/bios_version
MrChromebox-2606.1
❯ cat /sys/power/mem_sleep
[s2idle] deep
Sure thing. I am running the CachyOS kernel on Fedora Workstation without issue. I don’t know if that might be relevant to you or not.
RO version:    redrix_v2.0.22077-b620d4389e
Firmware copy: RW
Chip name:     NPCX993F
Board version: 3
MrChromebox-2606.1
[s2idle] deep
bash: slp_s0_residency_usec: command not found...
Let me know if I can be of any further assistance.
This is likely my last update on this build, it’s in a good enough place that I don’t expect much more to report. I consider it 99% complete and it is 100% stable.
I removed keyd the day after installing it and have not had another touchpad reinit failure using my touchpad resume/listener service. To be clear: this doesn’t fix the underlying touchpad reinit bug; that’s firmware/EC-level and shows up on every build I’ve run. The listener just automates recovery from it so I don’t have to manually flip tablet mode or reboot every time. In hindsight, keyd is likely the culprit behind my touchpad resume services failing to work reliably on previous builds. I used udev hwdb remap for the one function I wanted: caps lock.
Also regarding keyd, since I removed keyd the day after reinstalling it (due to the touchpad recovery failure covered above), I never got the extended uptime needed to properly test whether it was actually causing the shutdown hangs I was experiencing on previous builds. The single overnight it was installed, it rebooted just fine the following morning, though a single reboot after one night doesn’t really test the extended-uptime pattern the hangs required. I’ve not experienced any shutdown hangs at all on this build, but that’s not a controlled result on the keyd suspicion specifically; just noting it stays an open theory rather than confirmed either way.
Everything else (VPN, audio, tablet mode, Syncthing, etc.) has been solid. Remaining known issues, none of which I’m still actively troubleshooting:
  • Touchpad ELAN2703 reinit — firmware/EC-level, confirmed across every combo, the resume-listener service handles recovery perfectly (although I might consider decreasing the 5 second wait to 2 seconds)
  • Keyboard backlight stuck off after a cold boot — longstanding MC firmware quirk, fixed with a power off for 30 seconds, or simply powering off and then powering back on using the power button. With the excellent battery life during sleep, I just never power off and only reboot as needed
  • ~1 second battery icon flash to red/0% with a popup warning — cosmetic, harmless, been there since day one and only happens once, or maybe twice, during each discharge cycle. This has also been experienced this across all builds
I’ll also mention that I installed CachyOS kernel last week, and have not experienced any issues or regressions. It is locked in via the bieszczaders/kernel-cachyos COPR. Hit one snag with the first kernel update. Fedora patches kernel-install to bypass the standard postinst.d hook mechanism. Setting CachyOS kernel as default silently failed on the first routine kernel update. Fixed it by switching to a libdnf5-plugin-actions hook instead, which ties into DNF’s own transaction completion rather than systemd’s kernel-install. Confirmed working across two real updates since (7.2.5→7.2.6→7.2.7), with CachyOS kernel staying default each time with no manual intervention.
This has been a fun project over the last several months. It has served as a daily driver across all 3 of the builds I have experimented with. I’ve learned so much and have taken plenty of notes. I know I won’t retain most of the knowledge I gained, but hopefully I can make sense of my notes if needed.
I would also like to share my project code name: ChrUMb.
It started out as
  • Chr = ChromeOS or Chromebook
  • UM = Ultramarine
  • b = book or build
After reverting back to MrChromebox, I had to change its designation:
  • Chr = Chromebook
  • U = Ultimate
  • M = MrChromebox
  • b = build
