[REDRIX] Camera sensor HI556 (INT3537) fails with Code 10 (STATUS_DEVICE_POWER_FAILURE) on MrChromebox-2606.1 in Windows
Device: HP Elite Dragonfly Chromebook (REDRIX, Google_Brya family)
OS: Windows 11 Pro 24H2 (x64) (also reproduced on Build 28000)
Firmware Type: UEFI Full ROM
Firmware Version: MrChromebox-2606.1
Internal storage type: NVMe
The MIPI camera sensor ACPI\INT3537\0 (Hynix HI556) fails to start in Windows Device Manager with Code 10 (0xC000009E: STATUS_DEVICE_POWER_FAILURE).
Key Investigation & Diagnostic Context:
  1. Hardware is 100% verified working: Booted into an Ubuntu 24.04 Live USB on the exact same machine, and dmesg confirms intel-ipu6 successfully initializes CSE authentication and detects the sensor (Found supported sensor INT3537:00, IPU6-v3[465d] hardware version 5).
  2. A/B Comparison with another identical Redrix: I have another identical HP Dragonfly Chromebook (Redrix) running MrChromebox-2603.1 where the camera works flawlessly with the exact same driver stack (iacamera64 + hi556.sys 63.22000.16989.1 + SerialIO 30.100.2417.30 + crosec).
  3. Driver stack on Windows is clean: Intel AVStream Camera (DISPLAY\INT3480), IPU (PCI\VEN_8086&DEV_465D), and I2C Host Controller (PCI\VEN_8086&DEV_51EA) all show Status OK (Code 0). The failure only occurs when hi556.sys attempts to execute the ACPI power-on sequence (_PS0 / _DSM / GPIO power rail toggle) on MrChromebox-2606.1.
  1. Flash MrChromebox-2606.1 UEFI Full ROM on HP Elite Dragonfly Chromebook (REDRIX).
  2. Install Windows 11 24H2 (or 23H2/22H2).
  3. Install standard Alder Lake Chromebook drivers:
    • Intel Serial IO I2C / GPIO drivers (iaLPSS2_I2C_ADL / iaLPSS2_GPIO2_ADL).
    • crosec driver package.
    • Intel MIPI Camera & HI556 sensor drivers (IntelMipiCamera installer).
  4. Open Device Manager → Check System Devices → Camera Sensor HI556 (ACPI\INT3537\0).
The Camera Sensor HI556 (ACPI\INT3537\0) should power on properly and show Status: OK (Code 0), allowing the Windows Camera app to stream video (as it does on firmware MrChromebox-2603.1).
Additional Logs & IDs
  • Faulting Device Instance Path: ACPI\INT3537\0
  • Parent I2C Controller: PCI\VEN_8086&DEV_51EA&SUBSYS_72708086&REV_01\3&11583659&0&AA
  • Kernel-PnP Event: Event 411: Problem 0xA, Problem Status 0xC000009E
  • Linux dmesg verification output:
    [ 12.629236] intel-ipu6 0000:00:05.0: Found supported sensor INT3537:00
    [ 12.629350] intel-ipu6 0000:00:05.0: Connected 1 cameras
    [ 12.630697] intel-ipu6 0000:00:05.0: Sending BOOT_LOAD to CSE
    [ 12.640088] intel-ipu6 0000:00:05.0: Sending AUTHENTICATE_RUN to CSE
    [ 12.711877] intel-ipu6 0000:00:05.0: CSE authenticate_run done
    [ 12.711886] intel-ipu6 0000:00:05.0: IPU6-v3[465d] hardware version 5
roll back to the previous firmware and verify it works under Windows, to rule out something specific to that install. if it works, dump the ACPI for both versions so I can compare. I’m pretty sure nothing changed though.
My bad on the earlier post — I pasted some raw AI debug output without really checking it first, which made things way more confusing than they needed to be.
I went ahead and dumped/disassembled the DSDT and SSDT tables with iasl from both machines (the working 2603.1 and the failing 2606.1). Turns out you called it — the CAM0 / INT3537 block is literally identical. The minor SSDT diffs were just unrelated stuff like DPTF, S0ix, and RTD3 on other I2C buses, none of which touch the camera’s I2C2. fw_config and EC versions match up across both units too. I also flashed this unit back to 2603.1 just to be 100% sure, and the issue was still there.
So yeah, firmware is definitely ruled out. Still trying to figure out why this specific board is throwing that power-up error on Windows, but I’m going to set up camera capture under Ubuntu next to see if I can actually pull video frames there and narrow it down.
Thanks for the sanity check and for maintaining the firmware!
different boards did use different camera sensors IIRC, worth comparing between the two units
