- Device: Samsung XE525QBB NAUTILUS
- OS: ChromeOS
- Firmware Type: Stock
- Firmware Version: [As reported by the script]
- Internal storage type: [SATA, NVMe, eMMC, UFS] (if applicable)
Any way to enter recovery mode without the use if the refresh key? Several keys are non functioning atm, including the refresh key. I assume that particular key is mapped directly to a reset/boot pin, but is the device’s keyboard required after I enter recovery mode? Can I open up the integrated keyboard and short the conductors on that key to send the keystroke and continue the process with keyboard connected via USB? Is the juice worth the squeeze?
Break keyboard
Try to flash linux
Push the buttons, do the thing
