Recommended Linux distros structuring question
The recommended distros section on the installing Linux page contains the following list.
  • Arch Linux or EndeavourOS
  • Fedora or Ultramarine Linux
  • openSUSE Tumbleweed
  • Pop!_OS
Shouldn’t the list be something more like the following with the distros listed separately or is there a specific reason why it’s not like that?
  • Arch Linux
  • EndeavourOS
  • Fedora
  • Ultramarine Linux
  • Pop!_OS
Both Endeavour and UM are, to put it simply, preconfigured derivatives of their respective parent distribution and can be considered the same.
Ah, that makes sense. Thanks for the clarification!
