Random shutdowns when using with battery only
  • Device: Craaskvin
  • OS: Windows
  • Firmware Version: 2609.1
  • Internal storage type: eMMC
I recently installed Windows 11—and also tried Windows 10—on a Craaskvin; the firmware is dated october 1 2026 (2609.1) , yet the random shutdown issue persists. I’ve noticed that if I plug it in to charge when it’s at partial capacity (say, 80% or 90%), it shuts down once it reaches 100%. The shutdown process is normal (Windows closes and the “Shutting down” message appears); it isn’t like a sudden power cut.
Note; deleted my previous post because wrong section.
How did you unlock your Chromebook and flash the UEFI?
Normal; i guess, first enabled developer, then several gsctool commands (PP many times) and finally the Mrchromebox script.
I’m asking: did you disconnect the battery to flash the UEFI, use a programming clip to force-flash it, or use a SuzyQable/Suzy-Q debug board with CCD protection disabled to flash it?
Nothing that, my chromebook isnt enrrolled, i dont needed remove any screw.
