I need some help on a random hibernation on my Asus C425TA at 70-80 % battery level. This chromebook was put on full-ROM Mrchromebox firmware and LMDE 6 in late July 2024. I believe the firmware should be 2405. I spent a long time in making audio working with chrultrabook audio setup (kernel 6.6.43) in July and August.
I upgraded LMDE many times according to Mint upgrade cycle. (I prefer using LMDE kernel when there is no need for audio support for security reasons.) But I noticed that once I upgraded the firmware from 2405 to 2408 a fews day (around 15 October 2024) after the LMDE upgraded to Debian 6.1.112 (4 October), the battery problem occurred. The Asus chromebook became erratically hibernated at around 70-80 % batter level. It occured to me 2 times already during a normal Intenet usages. Telltale symtom was the battery warning popup at 0 % and automatically hibernated immediately.
I plugged the power right after the hibernation, and tried bringing up the Asus. Surprisingly, the battery level reported at 70-80 %.
I regularly plug in the power supply only when the battery leve reaches 20 % (and charge until it reaches 100 %).
I did not find any unusual events occured in var/log/syslog prior to the hibernation.
Is there a possibility to downgrade Leona (Asus C425TA) firmware to version 2405?
Sorry for a long description, and thank you for your support.
