Question about RW_Legacy partitions
Can the Chromeos ESP be safely resized when using AltFw? The docs claim that you can just reformat the chromeos ESP and use it as the AltOs ESP, with the added benifit of edk2 not trying to boot chromeos by default. However, it is a 16mb partition when using a 1Gb partition as your ESP is recommended by the Arch wiki. I’m planning on dual booting arch with chromeos.
I don’t believe so, given the partition layout/placement, but haven’t tried recently
Is is safe to use the chromeos ESP as the Arch ESP though? Or will it be necessary to make a new partition? Will there be any repercussions of doing it one way or another?
Thanks.
ChromeOS doesn’t use it at all, wipe and use as you see fit
