[Q] Is Lenovo IdeaPad Duet 3 10ILG5 82AT002VGE N4020 4GB / 64 GB supported in general?
Hi out there !
I could get a hold of an Lenovo IdeaPad Duet 3 10IGL5 82AT002VGE (N4020, 4GB RAM, 64 GB SSD). Yet it seems to run Win10 22H2. For various reasons I’d like to replcae Windows by a Linux distro.
I did browse thru the list of supported devices without success. Usually this indicates rare chances. But I’ll give it a try … :wink:
So you experts: Any chance to get it running the way I’d like to ?
Any feedback is very much appreciated !
Best regards, dragonfly7
support is by board name/ HWID, not make/model.
that said, based on the CPU platform, one can be sure that it’s supported
I know this thread is a bit old but I wanted to give my own response as well…
After looking around I found that the board name for your Chromebook is “WORMDINGLER” (from cros.tech) (yes, dumb name). I put this board name into the MrChromebox Supported Devices page and found nothing.
Even though nothing showed up, it’s likely that your Chromebook could be supported but I wouldn’t bet too much on it. The main thing that catches my eyes is the “Intel Celeron N4020” as that’s a CPU used in other supported Chromebooks.
WORMDINGLER is an ARM-based board, not an Intel one. This is why you don’t try and determine the HWID/board name from the make/model – you look it up the right way on the device.
