ENA1
January 27, 2024, 6:05am
1
So I got linux mint on my chromebook, and the audio does not work. I tried the guide chrultrabook has to fix that, it didnt work.
FIXED: I fixed this weird factory resetting thing my chromebook would do whenever i shut it off, so i re tried that script and audio works.
ENA1
January 27, 2024, 2:29pm
3
I already did go to the docs, it didnt work.
The debug script didn’t work?
ENA1
January 27, 2024, 3:12pm
5
It for some reason didnt. I did all 3 steps, restarted, nothing.
(Also woah i didnt think the creator would see this!)
BluRaf
January 27, 2024, 3:34pm
6
If you would have read the instructions, you would see that the debug script will only generate the file on the desktop, that you are supposed to upload here…
ENA1
January 27, 2024, 5:54pm
7
There were no instructions, it just showed those three scripts i had to input.
Did you even click on the link that elly sent?
ENA1
January 27, 2024, 6:18pm
9
I feel like an idiot now because when it was sent I thought she just sent the link to the docs (like the start of it.) I’ll check it out now, but theres another issue that may be the reason. I just edited my post.
ENA1
January 27, 2024, 6:34pm
10
I just fixed the problem with it factory resetting. im gonna re try the script now.
ENA1
January 27, 2024, 6:43pm
11
My apologies, I didnt read it and thought you just sent the chrultrabook docs (the start of it.) Im trying this out now.
sadlerm
January 28, 2024, 12:55am
12
You’re only supposed to do the section “ACPI and Linux kernelspace”
sadlerm
January 28, 2024, 1:32am
14
You don’t have to do any of this. Run the debugging script, it will spit out a tar archive, which you can then upload here.
ENA1
January 28, 2024, 1:39am
15
oh, alrighty. Just upload it in the replies or the post itself?
