Problem activating legacy boot on HP chromebook
Hello guys, I have a problem, I already have a memory card with Debian installed, ready to be booted, I activated developer mode, and when I clicked the ctrl + l keys, it appeared to activate legacy boot, I went to the shell, I used dev_boot_usb =1 and dev_boot_legacy=1 and it appeared that I should use dev_boot_altfw, I used it and tried again, but the developer mode screen simply crashed and nothing happened, what should I do? the architecture is aarch64 and I don’t have enough memory to install Linux in internal memory, only on the micro SD.
AltFw doesn’t exist for ARM devices, you need to use CTRL+U to boot from external media on ARM, but the kernel needs to have a ChromeOS signature.
ohh okay bro, I did the process but it said “boot lrom is not enable”, what do I do now??
no idea what that means
