The audio script doesn’t support this distro, and it’s taking forever for my USB to wipe and get an Arch based distro on it, so is there any way to fix/bypass it? I’m getting some incompatible syntax 7 and failed to import errors. (Worked wonderful on Endeavour os)
post a log with the output of the script, version of Pop used, etc.
summarizing a problem provides nothing of use for diagnosis
Output of ./setup-audio:
”Detecting platform
Detected Intel Jasperlake
Installing UCM configuration
Cloning into ‘/tmp/alsa-ucm-conf-cros’…
remote: Enumerating objects: 117, done.
remote: Counting objects: 100% (117/117), done.
remote: Compressing objects: 100% (86/86), done.
remote: Total 117 (delta 38), reused 88 (delta 24), pack-reused 0 (from 0)
Receiving objects: 100% (117/117), 20.07 KiB | 395.00 KiB/s, done.
Resolving deltas: 100% (38/38), done.
Checking kernel config for 6.17.4-76061704-generic
Detecting codecs
Found rt1015p
Found rt5682s
Kernel config check passed
Increasing alsa headroom (fixes instability)
Initializing sound card
alsa-lib parser.c:270:(parse_syntax_field) Incompatible syntax 7 in sof-rt5682.conf
alsa-lib main.c:1541:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -22
Found hardware: “sof-rt5682” “Intel Jasperlake HDMI” “HDA:8086281a,80860101,00100000” “” “”
Hardware is initialized using a generic method
Audio setup finished! Reboot to complete setup.
Warning: Your distro is not officially supported. Expect Issues.
Please try a supported distro first before opening an issue. See the README for a list of supported distros.”
Pop!_os version: 22.04 LTE
@WeirdTreeThing this is your dept
I have too many issues to be worried about to have time to support an OS from 2022.
Dw I took time to switch to endeavouros again. Since pop os had many issues I just called it quits. Now the audio works perfectly!!!
